What is that strongest glue to glue wood to wood period. For indoor use.
things like PL 400, PL premium, epoxy, yellow pva, gorilla glue, fish, urea formaldehyde, etc.
thanks
thanks
Most of the glues when used under ideal conditions are usually far stronger than the wood itself so for ordinary cabinet work there is little practical difference.
Under less than ideal conditions, high moisture levels, vibration, stress, laminating, exotic wood species, et-cetera then the glue needs to be chosen for the specific conditions. Usually the best approach is to do some research to narrow down the choices and then to contact the glue manufacturers to pick the specific glue type, formulation, and application technique.
John White
thanks for the reply. forget about stress, the real answer is pl400. this is a structural glue and gap filling as well.
thanks
The only packaging I've seen for PL-4000 is in caulking tube cartridges, is that what you are referring to?John W.
yes that is correct. PL-400
It is the strongest glue period. thanks
