I’m looking for a reasonably priced hvlp spray gun that will give me a decent finish with water based lacquer. I have a three stage turbine. Also any brand recommendations would be helpful. Thanks…
Here is a recent (couple of days ago) discussion on this subj
23401.1
there was a more thourogh one a little while earlier check the archives
Caution: This message may contain "For Official Use Only" (FOUO) or other "sensitive information" is not intended for non-official disclosure. Do not disseminate this message, except to persons who require it for official Breaktime purposes, without the approval of the individual originating this message or other authorized official of the Taunton University. If you received this message in error, please delete it.
Thanks Ron, the articles were very helpful.
No prob chucky. If you would the archives Im sure you would find alot of info on this subj. It has been discussed in length several times
another one
22997.1
Be extra careful with the WB gun selection. I specified that I would be using WB product primarily, had some problems with the equipment corroding & rusting, now cannot get support from the company that I purchased it from.
Chucky,
For water-based finishes, it's best to use a spray gun that has stainless steel fluid passages and needle/nozzle. The solvents in water-base react with other metals.
You can use a spray gun that doesn't have SS fluid parts, you just want to make sure you don't let the finish sit in the gun when you're not spraying. If you spray a coat and then give it a couple hours to dry, it's best to empty the gun and rinse the fluid passage well with warm water.
Are you looking for a gun brand or water-base lacquer brand recommendation?
Website
Brand names would help, thanks...
Turbine HVLP spray gun - the Accuspray #10 gun is top of the line and also works with a compressor. I have some Graco turbine guns and they spray very well. The Wagner turbine gun sprays well also.Water-base finishes - I've used or tried a number of brands and like the finishes from Target Coatings (http://www.targetcoatings.com) the best. They have a water-base lacquer with 100% chemical "burn-in" between each coat.
Paul S
Website
I thought I would hop in and remind that I'm selling two unopened gallons of Target Ultima Semi-gloss.
Contact me if your interested, their new and unopened. Shipping carton isn't even opened. Have extra from last job.
I'll open the carton and sell single gallon if you want, $25 gallon plus shipping.
Its the same price the business I bought them from wants for a return. 25% restocking fee. Mildly tweaked since they have already made money on the sale (the other stuff I bought) and would just put it back on the shelf and sell it full price, about $35/gallon. Handling=open carton, put back on shelf.
Would rather give someone a deal than give them the money twice.
