I am looking for a satin or semi-gloss solvent based (not water) lacquer for spraying. Any help please.
http://www.mlcampbell.com/products/categories/clear_topcoats
http://www.mohawk-finishing.com/catalog_browse.asp?ictNbr=26
Although it isn't recommended, I've been spraying Deft with nice results. Parks lacquer is still widely available. Sherwin Williams has a professional coatings division.
Spraying lacquer
Do you thin the Deft lacquer? Are you spraying with a HVLP gun?
Lacquer
Is this for a Guitar body ?
Also you can go with a gloss and rub it to satin -
SA
Spraying lacquer
No, this is for furniture and house trim. I would go with a high gloss on a guitar body.
Lacquer
For furniture and trim I can't add anything more then Hammer supplied to you for products -
Most lacquer finishes require thinning. It's a balance between nozzel size, air pressure, and fluid feed. You may want to pick up some retarder - it will give you the ability to brush lacquer on interior trim.
SA
Spraying lacquer
Thanks for the information
I use an HVLP conversion gun, DeVilbiss Finishline with a #3 HVLP air cap. Most of the professional lacquers come ready to spray, I use Deft straight from the can, too.
