I’m a spray gun rookie just practicing with waterborne lacquers. Does the gun (HVLP compressor driven) have to be cleaned between coats? I have been recoating every 2 hours.
It shouldn't need cleaning in 2 hours. One tip is to put a plastic trailer hitch ball cover with a wet paper towel in over the air cap. It keeps the tip from drying up and clogging.
Thanks. That'll save a lot of work.
I've sprayed waterborne polys for a number of years and found that the tip of the gun will almost completely colse off in between coats. So as soon as I'm done spraying a coat I wipe the tip off with a moist cloth and use a toothpick to remove material from any crevices.
