Hello All, I’m preparing to make new handles for my chisels. Spokeshaves seem the correct tool for this. I’ve never used them. I also plan to use them to make make furniture. I’m looking at L/N Brian Boggs-type, or the Veritas Flat model. Questions: Should I get both flat and concave right now, or will I be able to use one for a general purpose shave until I get used to the tool? I see some smaller spokeshaves and wonder if I should consider that size as a first purchase. Any hints, tips, warnings are appreciated. –jonnieboy P.S. Or maybe what I really need is a drawknife?
There are a lot of ways to shape a handle -
The flat spoke shave is easier to use + sharpen -
Just get the one shave and see how it works for you -
They also make a convex -
SA
If you get younger spokes, they won't need to shave for a while. ;-)
There's quite a variety of spokeshaves around, from old wooden and cast-iron models to the nifty new LN/Boggs and Veritas versions. Except for the concave models, they are essentially just simplified block planes with handles on the sides. Or, as TLN would say, "Just a jig to hold a chisel". ;-)
The flat-bottom model, I agree, is the place to start, since it gives you a registration surface for and aft of the blade. The curved bottom is a little more "artful" - assuming your wrists are strong enough to be able to sweep through the cut.
I'm headed out to
I'm headed out to Woodcrafters in downtown Portland. Someone, cancel my credit card before I get there!
"Only a bullet gonna stop a buck in rut."
--jonnieboy
Hi jonnie
I have the Boggs and it is excellent, but for you I would instead recommend the LV. The reason is that the Boggs is essentially a finishing spokeshave (tight mouth), while the LV uses shims to open and close the mouth. Both are top rated spokeshaves.
An alternative is to additionally get a vintage Stanley #51 (the adjuster-less model) or the #151 (with adjuster) ... (I prefer spokeshaves without adjusters for balance) ... These have wider mouths and make a good "jack" (removing waste fast, before moving onto a finishing shave). I use a #51 for this.
Get a flat bottomed shave. Do not get a round bottomed shave at this stage - they are difficult to use ... and you really do not need one as a flat shave will do all but tight curves. I'd rather add a convex shave to the list (LV have a matching version) as these are handy on round handles.
Consider:
Boggs or LV (not the LA type)for finishing.
LV (above) or #51/151 for rough work
LV LA for end grain
Also think vintage!! The Stanley #53 and #54 are two of the best around - they have adjustable mouths and so do it all. The only downside is that you cannot get a thicker blade into them. They differ on handle shape (the #53 is higher than the #54, which is straight). I have the #53 and think it is the best thing since sliced bread.
Others: The HNT Gordon range are superb - easily the best around on interlocked grain (they have high cutting angles).
Derek..
Something for you to do for in here with all your lovely pictures... Sharpening spokeshaves!
I have several 'spokes' I use all the time. Never figured out how to properly sharpen those 'curved' ones! For my curved spokes I usually just 'dress/hone' with different grade 'grits' on a linen buffing wheel. Seems to work for me, but what happens if I have to grind one? I am lucky in that I have a bunch of cylinder/tapered cone shaped stones from my metal working days that I can use.
ALSO, I have never figured out how to sharpen a 'V' carving tool that could ever, cut again.. After I worked on it!
This a great guide, Derek. Thanks for taking the time.
I'll let you know what I end up with.
--jonnieboy
