I’m cutting grooves in mitre joints and getting tear out, and I wonder why and what I can do about it.
I’ve got a 1/4″ onsrud sprial router bit (1/4″ shaft) mounted in a 2 hp Bosch router in my homemade router table. I clamp the mitred walnut to a sled jig and slide it over the router bit to make a cut 1/4″ deep. I’ve tried pushing slowly and at moderate speed, but I always get tear out where the down-spiral bit enters the walnut.
Jim Bell
Jim,
I can't tell you why you're getting tearout, but you could try other bits, slowing the router speed, using a "backer" strip against the mitered piece so that the bit enters that first, then passes into the mitered piece.
I use a Freud FTG ripping blade to cut spline slots. No tear out. See the attachments.
Rich
Thanks. I'm cutting long splines or through splines (3 1/2" this time). I changed to a Freud 1/4" bit (fairly new) and still got some tear out.
Do you also cut the through spline grooves on the tablesaw?
Jim
jim,I'm not sure what you mean by through splines.That's interesting that using a router is causing a tearout problem. I was going to do it on the router also, but once the rip blade method worked so well I never tried anything else. I wouldn't have anticipated the problem you're having. How about applying masking tape firmly to the entrance point of the cut?Rich
I use the table saw instead of the router. I find it works much better.
You can use a biscut cutter too
I'd vote for cutting the spline groove on the table saw. With a left tilt powermatic saw it is easier than cutting the original miter.
The saw blade may not be 1/4" though, and not leave a truely flat bottomed groove. The one I'm using is a bit bigger than 1/8". I don't recommend trying to make two passes with a single blade to get a 1/4" groove, but you could certainly put a dado set in there with 1/4" worth of blades to do the same job your router is making hard for you.
I teach furniture design to college kids, and in the first class they take thay all have to make a "joinery box" that has one splined miter corner. We used to use the router, but dropped it for the table saw after getting too many complaints about tear-out like yours.
4D,The Freud FTG ripping blade results in a perfectly flat-bottomed cut.BTW, putting splines in the miter joint is just about the most bullet-proff way to make these joints (see the pics above). I made dozens of frames in Maui before I moved to Arizona. (A change from consistent medium to high humidity to an environment that changes from bone dry to ghastly humid, weeks at a time, several times a year.) The corners have remained absolutely tight. Not a sign of opening at either the inside or outside corners.With frames finished in the standard frame shop way, V-nails, brads and glue, opening and shifting of miters due to humidity changes is a fact of life.Rich
Thanks. I find it reassuing to know that entire classes of wordworkers have had trouble with router tear out on spline grooves in mitre joints. I'll try a 1/4" dado set on the table saw and see how it works. I'm thinking a stop block and a backing board, plus sharp dado blades (as my old Freud set is loosing its edge).
Jim Bell
