I have notice an increase in the use of spiral cutterheads in jointers (and planers). Are they significantly better than traditional knives? if you think so why?
I am about to purchase a jointer (anyone selling an 8″ jointer in the SF Bay area- or know of a local used dealer?) and am wondering if I should get one with a spiral cutterhead or stick with traditional knives.
thanks
Fine Woodworking Recommended Products
Waterlox Original
Versatile wiping varnish is easy to apply and great for both satin and gloss finishes.
Dubuque Clamp Works Bar Clamps - 4 pack
These clamps are as premium as their price is, but they're worth every penny. A few staffers have a small collection and they're almost always the first clamp they reach for.
Estwing Dead-Blow Mallet
A quality dead-blow mallet that packs and punch but isn't too heavy for furniture work.
Woodriver Rechargeable Desiccant Bag
- Begins working right away - Filled with 400 grams of Silica Gel - Absorbs up to 35% of its weight in moisture - Rechargeable in a 600-watt microwave for 6 minutes
Bahco Camping Axe
Total Length: 14.2 inches (360 mm) Blade Length: 4.3 inches (110 mm) Weight: 2.8 oz (800 g) Material: Tool Steel
If you are in a high production shop using figured wood, the spiral may be the way to go. Otherwise a sharp set of knives with the appropriate feed rate will handle most needs.
From the installation instructions I've seen, spirals are alot less fussy to install than most standard knives. You just install them and that's it: no tediuos adjusting to get them perfect, etc. They're also alot more expensive.
Barryo hit the nail on the head. Spirals are "set up and go". Or even "set it and forget it". They are more expensive though. I swapped out the cutterhead on my jointer for a "Shelix" cutterhead because I want to use the jointer. I don't want to spend hours fussing with the jointer. The indexed cutters are great, I get four cutting edges per knife and then I can swap them out quickly without any further adjustments to the machine. Clearly superior. Some claim that one gets a better cut with spirals, I can't really speak to that, but I can say that I am extremely happy that I spent the $ for the spiral cutterhead and would never return to straight knives again.
Good Luck!
John
I hear ya. I hate spending time sharpening blades, and fussy adjustments. I just don't enjoy it; perhaps some do enjoy "fine tuning" their machines, but I like to do as little as possible. My Makita planer has disposible, "set and forget" knives. Bandsaw blades are cheap and get thrown out when dull; carbide table saw blades stay sharp a long time and can be sent out for sharpening.
That leaves the jointer. the blades on it must be very sharp and precisely aligned if it is to do its job, so I'm thinking about going the spiral route (if I can stop thinking about the $$$).
I'd like to leave sharpening to the chisels and planes.
I was fortunate enough to pick up a slightly used ShopFox 8" jointer with the spiral cutterhead at the the Grizzly tent sale. I understand it isn't a 'true' spiral cutterhead. Regardless, I am extremely pleased with its performance. The quality of the cuts puts my planer to shame. I am very glad I paid a few extra bucks to have a machine with such a good cutterhead.
FYI: to date I've been working exclusively with hard maple. I've had some funny grain since I'm using utility grade maple, but nothing I would consider very figured.
