Could somebody tell me what software program would suit my needs from their experience. I build furniture for a hobby for myself and and for friends. I have had a couple of people want me to build their kithchen for them but feel I am not quite set up for that yet. I did do my own kitchen that turned out very nice. The way I do it now is sit down with graph paper and after alot of time draw it all out, then try and figure out how I can get the best use out of the wood without much waste. I hope to one day turn my hobby into a full time job. Any help will be greatly appreciated, Pat
Check out AutoSketch. I used it for my first set of commissioned cabinets and it worked well. I also use it for some furniture. You can create multiple layers on top of the cabinet boxes to represent face frames, doors and drawers. It helped me tremendously in getting all of the dimension down the first time prior to building. It's like pre-constructing the cabinets and I'm sure it save me a lot of headaches. There is a little bit of a learning curve, but not too difficult. The cost of the product is around $100-$150. There maybe other sketch type programs out there, but this is the only one that I am familiar with. Since you do custom work and one of a kinds this should work well. This product is compatible with CADD.
Aaron
If you're looking for a CAD type program, you can download Intellicad from http://www.cadopia.com - and 'evaluation' copy. It runs for 1000 (that's one thousand) sessions before it times out. It's got a pretty easy learning curve, that is if you have reasonable computer skills to start with, and is a more that AutoCAD compatible clone of AutoCAD itself although with limited 3D capabilities.
Dennis in Bellevue WA
[email protected]
I'm a one-man shop doing custom furniture. I use DeltaCad (http://www.deltacad.com). I considered the industrial CAD programs like AutoCad and the programs specifically designed to run big cabinet shops. They'll do lots of stuff, including 3D. However, because they'll do lots, the learning curve is long, and if you don't use it 8 hours a day you forget most of it. They're also quite pricey -- like $500 and up. In contrast, Deltacad does just enough to design and build one piece of furniture. It is quick to learn, and inexpensive ($40). Like most of the programs in this class, they'll let you download a free trial version.
What a good question, and I hope there are a lot of responses. I bought TurboCAD, for about $25 off of the web. Theliterature said it had 3d capability, but it didn't, unless you were building a house. What I would like to do is draw a piece in 2D, and then be able to see it in 3D, from various angles. Then adjust dimensions, look again, etc. Does anyone know if there is a user frinedly program, not too expensive, and of course easy to learn, that would do this?
I also bought TurboCad. It has a long learning curve because there is no manual on how to learn or use it. Turbocad try to charge you extra for courses to teach you how it works. Also it has some strange effects if you try to snap to a grid; dimensions do not add up etc. It is not an easy program to use so be careful.
It has already hit the circular file. I can draw a bit, as can all woodworkers, but I wanted to be able to see the different perspectives, which this software does not do. And, there is noone to talk to about what "3D" actually means in the context of this particular software. That is no accident, I suspect.
I can't speak to the design aspect of your question, and it looks like there is plenty of good advise here already on that but for cut lists and sheet optimization I use Cutlist Plus. You can get this at the link below. It allows you to specify either boards or sheet stock, and allows you to enter what you have in the lumber rack to use that up first. Works great. it's well worth the $25 bucks or so I paid for it.
TDF
http://cutlistplus.com/
