I’ve got a 14″ Jet bandsaw with a slipping tire on the upper wheel. When I remount the 3/8″ blade, it will track just fine, but the tire will be pushed off the wheel to one side or the other after just a few seconds of cutting. I’m following the directions in the manual for adjustments, clearances, belt tension, but the tire won’t stay put.
Any suggestions?
Just went thru the same problem. Time for replacement tires ie: urethane tires.
That is how you can tell that you need new tires.
