I’m making 20 kitchen cabinet doors of many different sizes with beadboard for the inside panels. Trying to find software to help me with the cutting plan for the sheet goods – any ideas? I’ve used Woodshop Calculator for the door part dimensions.
Bob,
Google "plywood cutting optimizer," and you'll come up with quite a list of software offerings. I've tried a couple those, but none of the less expensive ones satisfy my need proper grain direction or figure alignment. When I need to save on expensive material (like the wenge job we're working on), and insure figure alignment, as on slab doors, I do it by hand, using the attached MS Word drawing. It's relatively quick and easy.
Gary W
gwwoodworking.com
Gary -
DOC is a lot easier than DOCX for those of us who refuse to adopt Vista and Office 2007!
Point well taken. Here it is in .doc format.
MSWord 2007 has been a pain to set up and learn after 20 years of using word. Nothing really intuitive about it.Gary W
gwwoodworking.com
Gary. Simple but effective solution. You could also use Excel with 6" squares and internal dot borders. Thanks for doing the conversion. I appreciate your effort.
I'm not the person to ask on this subject, I've never used a sheet goods cutting program.
Most of my projects never use more than a sheet or two of plywood so I just lay out the cuts the old fashioned way. Personally, I use computers as little more than fancy typewriters, I never expect them to solve anything.
I think that it would be fairly difficult to get a program to effectively lay out the cuts in the best possible layout, there must be a at least a few hundred possible answers to any specific problem.
This would probably be a good question to post on the regular Knots site, there are a number of software experts there.
Sorry I can't be of more help on this,
John W.
"I think that it would be fairly difficult to get a program to effectively lay out the cuts in the best possible layout, there must be a at least a few hundred possible answers to any specific problem."
There can be a lot of possible combinations, but the better programs do quite a good job at it. I've been using CutListPlus, and have been surprised a couple of times when it suggested a better layout than I would have come up with by hand. It lets you make various kinds of "what if..." trade-offs. For example, you can optimize for the fewest number of cuts, care/not care about grain orientation, maximize the size of any offcuts, etc.
Thanks for the feed back, I'm sure the original questioner will appreciate the information. Now I feel challenged to try my skills against "the machine". I'm hoping to use less and less sheet goods in the future, primarily because they're so hard to handle in a one man shop, especially if you can't move the sheets right from the truck onto a cart or a dolly, which is the case in my shop.Thanks again,John W.
