I don’t know who to ask this, but I need to know if there is any difference in sharpening marking knives than in sharpening chisels or plane blades. Any help in this matter will be greatly helpful and appreciated.
thanx, newtowoodworking
I sharpen my marking knives the same way as chisels, but to a lower angle.
EDIT: Oh, I don't normally use a microbevel on marking knives.
Chris @ http://www.flairwoodwork.spaces.live.com
and now http://www.flairwoodworks.com)
Edited 6/24/2009 12:43 am by flairwoodworks
Not really. Marking knives are usually sharpened with a fairly acute bevel, 20-25°.
Knives and chisels are similar.
I have different types of marking knives. Some are heavy duty and used to score as deep a line as possible - such as these Japanese knives. They are honed with (I think) a 25 degree flat bevel, which is how they came. This is comparable to honing a Japanese chisel. In fact they all have hollow backs as well. I just side sharpen them on waterstones.
On the other hand, the knives that I make for marking dovetails have blades that are thin enough to fit inside a saw kerf and are just 1/4" across. Their main purpose is to score a visible line, so you do not want it to be too fine as it will not be seen against the endgrain. Also, you want durability of edge. So I hollow grind these HSS blades at 30 degrees, then freehand a coplanar bevel to 5000 grit ... a lot similar to Western plane and chisel blades.
