I often use a Beecham Skewchigouge for turning beads, for the initial shaping of a captive ring, etc. But I have a devil of a time sharpening it. Any advise? (I have a number of sharpening options, including a new oneway wolverine rig). I can’t figure out the right angle for the chisel, and end up freehanding it; which means the bevel is a mess.
Thanks, dan
dan,
pardon my ignorance, but what in the name of all things good, is a beecham skewchigouge??? can you post a photo?
eef
just googled it. man, that looks like a serious challenge to sharpen. the google search did show a pdf that describes what to do and not do when grinding. i see that one can get some tiny detail in it's use. would not mind trying one. more than likely, someone here will know what to do.
eef
Edited 6/13/2009 4:38 pm ET by Eef
Here's a link to the image at Woodcraft.http://www.woodcraft.com/images/products/140474.jpg It's a solid round rod. The top edge is easily sharpened (with a jig) by laying on the top of an 8" wheel. It's the bottom that's tricky. The sheet that you mention (I've seen several versions) is very sketchy. The idea is that the top piece is supposed to be a perfect ellipse. The chisel cut is the problem. I don't really know what the angle should be. (Of course, I didn't think to measure it when it was new.) The tool works like a spindle gouge, and also like a skew. It is really hard to have it catch. Sharpening advise much appreciated %^)
Hi Dan
I am either going to get this completely right .. or not .. since I have not used one like this. However, from the image it looks extremely easy to hone.
About a week ago I ground and honed a blade that looks very similar, so ..
You have a round bar and you want an ellipse? All you need to do is gring the bar at an angle, and you will automatically create a bevel with an elliptical back. This will occur whether use a hollow or a straight grind.
I would recommend (if you are using HSS) grinding on a disk sander. Either use the mitre gauge or make up a jig to reproduce the desired angle. What angle? Try 25 degrees.
Well, that's worth a try, but I guess I still haven't gotten this described accurately. Here is the Crown tool instruction sheet as tidied up by Woodcraft:
http://www2.woodcraft.com/pdf/77B87.pdf
Note that the top facet (the ellipse) is concave, and the "chisel" facet, the "bottom" one, swings around that elliptical outline, but doesn't intrude on it.
The tool came exactly like that, and for a long time I only put the tiniest hone on the chisel. But. . . hone it enough, and you've changed the shape. Now I can't quite recover the original.
Hi Dan
Hollow grind (instead of the flat grind I suggested before), and then grind a flat opposite the hollow (as if you were creating a bevel on a blade). The ellipse will remain but becomes pointier.
If you know someone who has a Tormek they can probably do exactly what you want.
Harry 6144
But, of course, I'd rather do it myself. . .Any Tormek guys out there who have an suggestions, I'd appreciate them. dan
