I have a shallow well pump that seems to loose pressure.
After the pump brings the pressure up to about 42 lbs the pressure switch shuts the pump off. The gauge shows a slow pressure loss over about six minutes then the pump kicks on it runs for about 2 minutes then starts the process over.. I know the logical answer is a leak somewhere. I can shut off the main line to the house thus elimnating any chance of being a leak in the house.This makes no diffence. I have no visible leaks anywhere around the pump/pressure tank.
Could the check valve that is between the well and the pump be losing pressure?( I have never done anything with the check valve) Could the issue be the piping in the ground or the well point. I should state that the home had plumbing installed in 1955 so I assume the well was put in then. Although the pressure in the house could be better I have no complaints. I have lived in the home 10 years and replaced the well pump twice.
Any help would be appreciated.
Is there a tank?
Mine has a tank - a small one - with a bladder in it. When the bladder went bad, I got the same problem.
hi,
bladder tank is new less than a year old..I am assuming this isn't the issue..
Thanks for all the good advice..I believe I will start with the check valve..
Sounds like a bad check valve to me. If you shut off the valve feeding the house lines and you have no water leaks replace the check valve.
Life is what happens to you when you're making other plans.
When your ship comes in... make sure you are not at the airport.
Mike,
I had the same problem for years. the first time I had to replace the check valve at the bottom of the well. This proccess was repeated several times over the course of 40 years. In between ,I had to replace the pump since the first one reached its life span. When the second pump failed after some years, I wised up and replaced the jet pump with one down in the well. Now we never have a problem. The pump never loses pressure or prime. I think its the way to go. Good luck
Jabe
Mike ,
I am with the bladder answere as well or a leak in the suppy line to the house under ground.
Tom.
I had this same problem 5 years ago. The problem for me was the supply line to the house, from the well, sprung a leak. I had to dig it up, and repair it. It turned out that a rock was under the line, in the original trench, and worked its way through the copper.
Assuming that the pressure tank is fine, I would move on to check the Foot Valve. A foot valve is a form of a check valve that is attached to the end of the suction line. It is spring loaded and has a conical screen on the end of it. If you replace that you should be back in business.
Derek Borne
It's usually the check valve or the strainer built into it.
Another source of foot valve failure is the lack of height between the well floor and the foot valve. Unless there is eight to ten inches of vertical space, debris may be entering the foot valve, and lodging in the seat - causing pressure leakage. If you are going to pull the riser, check both the pipe length and well depth. A close inspection of the valve flap and seat will tell the story.
Lapun.
Thanks for the comment on my shallow well pump issue.
I have determined the best thing to do is pull the riser and replace the foot valve. I was told by a plummber friend to replace the steel pipe with black PVC pipe. The foot valve being steel/Brass. How do I transition from the steel foot valve to the black PVC? What do I use to insure a good seal.
Teetoo,Surely the agribusiness where you buy the black tube will stock a range of adapter fittings if it is flexible (sold in rolls), or if it is rigid, that is sold in straight lengths, threaded and socketed, you will need to cut a new thread where you cutit to length.My point is that you should shorten the length to raisen the foot valve to ensure that debris present in any turbulence at the intake does not deposit any hard material in the sealing surfaces of the flap valve.Better luck with length of service after the replacement.Lapun.
If you have a pressure tank with a bladder, and the pressure drop still occurs when the valve between the pump and pressure tank is closed, then your problem lies on the pressure tank side of the valve, not with the pump or foot valve (assuming the pressure gauge is downstream of the valve).
It could be caused by a few things: Check valve is bad; pressure tank bladder is leaking; limit switch is bad or out of adjustment; pressure in bladder is incorrect. (When the pressure tank is installed, add air via the fill valve (looks like a tire valve) to within 2 or 3 pounds less than the lower setting of the limit switch.)
kreuzie
Edited 4/17/2009 10:38 pm ET by kreuzie
Edited 4/17/2009 11:06 pm ET by kreuzie
