I’m making some shaker nightstands inspired by the casework of Christian Becksvoort and by the Shaker Dresser article by Michael Peckovich a year or two ago. I’d like to replicate the molding they use around the top of the case, but I’m not quite clear on how best to make it. It looks like it has a 1/4″ roundover on top and a 3/4″ roundover on the bottom. Is this made on the router table? Is there much handwork involved to get to the final profile? I assume the slots for the dovetail keys are routed after the rest of the molding is complete–is this true?
JM
You're correct on all counts. The profile requires 2 router bits and is accomplished on the router table. I start with a board about 4 inches wide, 1 inch thick, and a few inches longer than the case width or twice the case depth, whichever is greater. I rout the molding profile on each edge, clean it up with a block plane and sandpaper. I then rip the individual moldings off the board on the tablesaw. I find this much easier than trying to rout thin strips. Finally, rout the dovetail slot in the molding on the router table. By the way, I clamp featherboards in place to hold the molding down and against the fence during all routing operations. The featherboards also serve to keep my fingers away from the bit. This method should yield enough molding for the case front and sides. Use one strip for the front and the second strip for the sides. For proper grain match, keep track of the moldings as they are cut from the board. Crosscut the molding for the sides and reassemble with the front molding. Now swing out the side moldings from the center to create a U shape. This should give you a nice grain match from the front molding to the side moldings. Not as perfect as cutting all three pieces from one long piece of stock, but not bad.
Good luck, Mike
Mike,
Thanks for the info, that's very helpful. I don't have 1" thick wood, so I thought I'd rout the 3/4" roundover on the edge of a board, then cut it off on the TS, then rout the 1/4. I'm going to try doing it on a long board to get good grain matching, which should only require being accurate on the miters, I think.
Thanks for your help,
Joe
