Send us your questions about woodturning
FineWoodworking.Com needs your help with a new set of videos about woodturning. Send us the question you’ve always wanted to ask–What gouges and skew chisels to use. How to use turning tools. What woods turn well. How to sand and finish bowls and spindles. Whatever is on your mind. <!—-><!—-><!—->
We’ll select up to 10 of the best questions to use in the video series. Master woodturner Mike Mahoney will answer the questions on camera.<!—-> <!—->
Post your questions here by February 15.<!—-><!—->
Thanks for your help and your interest in FineWoodworking.Com.<!—-> <!—->
David Heim
Managing Editor
FineWoodworking.Com
How do I handle "difficult" grain when turning a bowl? My method is to sharpen my scraper as sharp as I can, then take as light a cut as I can. Do you have any better techniques? (Then sand like hell...)
Typically I try to do a rough turning while the wood is green and finish the turning after it dries out.
Bill
Please tell me about lathe speed control, especialy when starting with a wood billet to be rounded into a table leg. Some say start at slow speed, but others say that to round over square edges, faster speeds (mid-range) are better. It is confusing to me.
Further, for what operations are the slowest speeds used and for what operations are the fastest speeds used? I would guess that safety issues come into play as well as quality of cut issues. Should speed settings vary with the tool being used (ie, large gouges, finger gouges, skews, etc). Also, do "speed setting rules" vary between stick (between centers) turning and bowl turning? How does lathe speed vary between outside bowl work and inside bowl work?
Michigan Dave
David,
I have watched a few videos on woodturning on the web and on DVD and as a new woodturner I can tell you that no one talks about what goes through their mind as they look at a blank on the lathe and what the end design should / could be. Even pointers on things like ... if this is what you want to make then start with a blank with these typical characteristics. I understand that there are always surprises in the wood that change your initial design but not everytime out. Understanding what the design choice requires in a blank and how that needs to be adjusted as you turn the piece would be very beneficial.
Thanks for all the great information and help that Fine Woodworking, Finewoodworking.com and the community of fellow woodworkers provide all of us beginners!
John
I would appreciate a Glossary of 'techincal' jargon used in woodturning
For example (but not limited to):
1) What is Swing? Lathes are described as having a 6" swing. Does that mean you can mount a 6" blank maximum or a 12" blank maximum?
2) Tool types - for example, Gouges: Spindle vs bowl vs fingernail vs roughing etc. Same for Scrapers: left hand vs right hand vs end grain etc.
Thanks for the opportunity to learn!
Roy
David,
I think that an article on what makes a great lathe great would be awesome. I wouldn't focus so much on how brand X is better than brand Y, but more on what key features to look for. Features like variable speed, mass, runout, Morse tapers, spindle threads, handwheels, horse power, etc. Many turners make their own lathes. How about a basic plan for a lathe, which the individual reader can customize to meet their needs. For example: provide plans for a lathe with a short (~24") bed with, say a 5" swing over the bed. A spindle turner could lengthen the bed to 48" or longer, while a bowl turner could shorten or elimate it altogether. Thanks for asking for ideas - it really gets me thinking. Now I have another project at the end of a very long list!
Chris @ flairwoodworks
OK, I have no class so here goes..
Yesterday I watched the video on
http://www.woodmagazine.com/wood/file.jsp?item=video/player&temp=yes&bcpid=979295690&bclid=1338929761&bctid=1357340884
Hope the link is correct...
I wanted to see the 'Dovetail Showdown' and I saw the video 'Turned Toothpick'.. Some guy using the little RICON lathe (No I do not have one but I do have the 18 inch bandsaw (I like it ALOT).
Anyway, My first thought was.. That would make a GREAT tool review.. As in the same guy turning the same sized object on different tools for review..
Any tool.. Not just woodturning..
I'm the type that does not belive what I read but what I SEE (or thought I saw!) is a different matter. OK.. SO you can fudge ALOT with a well edited video.. But..
My request is for some video or demonstration of spindle turning. Please include use of the skew. I have seen some good stuff on the spindle gauge but I want more on the skew.
Interests:
Straight edge or curved?
Hollow grind then bevel angle?
Cutting with toe or heel when rolling a bead?
Leave the edge of the tool with square edges or round them?
I have the traditional flat skews sharpened on the wheel with a straight skew hollow ground. A little work on the stone and back to the spindle. I'd like to hear and see some other information from other turners.
Photos: spindle types for chairs.
Edited 1/26/2008 9:38 am ET by danmart
