I’ve got some green wood I need to seal (the end grain). Are there other products besides Anchorseal for this purpose? I can’t find a quick and easy source for Anchorseal. If you’ve got a source please let me know as well. Thanks.
John
John
Parrafin wax dissolved in kerosene works but needs renewing after a couple of years.
Oil based paints will also work.
I used the green wood sealer from Woodcraft, $9 a quart, probably all i'll need in my lifetime. Worked well. agriffee
Thanks. I've ordered some and this should do it.
John
John,
In my amateurish attempts with green wood, i found the best thing to do was slab it as soon as i could, trying to miss the pith core if there is one. Best results were to put the chunks in black plastic bags (you don't want to make a little greenhouse with clear ones) and let it dry slowly. I haven't had a lot of luck with end sealing; it just seems to slow down the inevitable when i've tried it with paint or wax. Not that i don't think you should do you part to keep the economy going... <G>
Johnhardy,
I use cheap wax, melted from old candles obtained from thrift stores et al. Melt the wax in a double boiler and paint the endgrain thickly with an old natural bristle paint brush but first make sure the pith of the log is halved. Sticker the stock to allow for air circulation then 'forget' about it . The hardest thing for me is letting the wood air dry for the long length of time per thickness- up to 3-4 years or more for 8/4 or 16/4 stock. After many failures, I learned to fell trees in the late fall when the sap was down and I learned to leave the bark on. Then I had fewer disappointments with stock degrade. I don't see the need for buying a product such as anchorseal when various other (thick coats of old oil or latex paint, wax, glue on end grain and branch protusions) and other cheaper methods work just as well. For example, Ron Kent claims to have good success controlling drying problems in green bowl turning work with a solution of cheap dish soap and water. I think the most important part of drying green stock is in the gradual dehumidifying process. That means starting the process in a cold and humid space and over a long length of time moving the stock into normal room environments. One could build a kiln or drying room of some type to hasten this situation of course.
sawick
I get anchor seal from Baileys $46.00 for 5 gallons. Not a bad price. http://www.baileys-online.com or 1 800 322 4539. good luck RL36
