I chose a Triton 2-1/4 HP router for my table because of FWW recommendation and the built in lift.
After about 1 hour of use, the Triton height adjustment gear broke, putting me out of commission for 6-8 weeks until a replacement part can be boated over from the orient reinforcing my philosophy that warranties today are virtually useless.
So now I must buy another router or take a two month hiatus.
DOOR #1: $220. The most economical choice is another identical Triton since it fits my drilled table insert. But I am unsure if this is a design flaw or a 1 in a million fluke.
DOOR #2: $285 For the Milwaukee 5625. This motor uses the same table insert as my Triton and the PC7518.
DOOR #3: $570 The Milwaukee 5625 and a lift like the INCRA-JESSEM Mast-R Lift. I’ve read the aftermarket lifts are beefier than the built-in versions in routers.
I am considering the Milwaukee because:
I got two user reports by people who make router accessories that the Milwaukee purrs like a kitten compared to the PC7518 which they described runs like a tractor and everything sitting on the table vibrates onto the floor.
The Triton seems to be a good router with good design features. Robustness is in question. But I am not impressed with the customer service and the method of operation that Triton chooses.
If I choose another router, I would need to replace my table insert ($100).
Greg
Exo 35:30-35
Edited 5/12/2009 8:16 am by Cincinnati
DOOR #2: $600 The Milwaukee 5625 and a Bench Dog lift. Thats what I have and the Bench Dog lift is built like a tank, I cannot imagine it breaking. If the Milwaukee ever needs service it should only take a feed days.
Life is what happens to you when you're making other plans.
When your ship comes in... make sure you are not at the airport.
I was at the woodworking show last winter and the sommerfield router bit company was demonstrating their bits and router table and they used the Triton router and I was impressed with the built in adjustment mechanism along with the sommerfield table. I've heard thought that Triton has filed for bankruptcy so I don't know if I'd go for another one(I may be wrong but I thought I read that here).
I myself still like my setup I have the the PC7518 mated with the woodpecker PRL in a Norm plan built table with the Incra LS fence system. One heck of a setup and accurate as the day is long. Now keep in mind I bought the 7518 removed the stock base and put it in the PRL to never be removed again. I just recently added a wixly digital adjustment that I really like as well.
Bones,
That router cabinet is enough to make Norm jealous. Great job!
GeorgeYou don't stop laughing because you grow old. You grow old because you stop laughing. - Michael Pritchard<!----><!----><!---->
Thanks. That was my first project getting back into woodworking after being out of it for about 10 years. The nice looking part I cant claim. The wife does stained glass and did the window. It was a blast to build. I've used it almost as much as the TS. The incra fence was used I got that from someone selling here.Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
Not clear on what you're asking but:
A 5625, x itself, works just ducky upsidedown.
I'm with you, Pat.
Greg,
How about Door #4?
Take a look at Woodpecker lifts. Their customer service is great. I own a plunge router lift with a Hitachi MV12. After many hours of use. I noticed that it became harder to raise the lift. If I had stopped and actually took a look. I would have found a the router was packed with sawdust. (I'll explain that if your interested.) But I didn't and ended up bending the threaded rod that raised the router. I called Woodpeckers and told them of my stupidity and asked them how much it would cost to get a replacement rod. (I have had the lift for several years.) They said nothing just ship it back. I did and in a week had it fixed. Oh, and they upgraded the lift to the new version as well.
Hope this helps.
"You cannot antagonize and influence at the same time. " J. S. Knox
