I was looking to buy a 3/8″ spiral router bit and found ones with 3/8 diameter shaft and ones with 1/2 shaft. There is quite a difference in price.
Would 3/8″ work in a 1/2″ collet? I’m assuming not and would have to buy the 1/2 diameter. But thought I would ask before purchasing the more expensive bit.
You need an adapter bushing to use a 3/8" bit in a 1/2" collet. Lee Valley sells one for $4.50: http://www.leevalley.com/wood/page.aspx?c=2&p=30126&cat=1,46168,46180
A 3/8" diameter spiral is commonly made from a solid 3/8" blank. To make a solid with 1/2" shank requires a stepped blank which is considerably more expensive. The Freud versions have 3/8" carbide spirals brazed into 1/2" steel shanks and are more cost effective than the solids. The 75-102 is an example:
Freud America, Inc.
Upgrade to Festool ;-) They have 3/8" collets.
The cost for bits is minimal compared to a new router.
Personally, I'am not a big fan of the reducing bushings for collets.
Bruce S.
"The cost for bits is minimal compared to a new router."
LOL! Only if the router is a Festool! ;-)
My router bits (almost all of which are 1/2" shanks, which would be useless with a Festool) probably cost 10X what the router cost me.Mike HennessyPittsburgh, PAEverything fits, until you put glue on it.
<<almost all of which are 1/2" shanks, which would be useless with a Festool>>?I have 3 collets with this tool. 1/4", 8mm and 1/2"
Better life through Zoodles and poutine...
Ah . . . I had understood from a prior post that the Festool collet was 3/8".Mike HennessyPittsburgh, PAEverything fits, until you put glue on it.
If you go to the parts sheet for your brand of router you will probably find that you can purchase a 3/8" collet for your machine. Most of the better quality machines have less common collet sizes available.
I would second the opinion that using a reducer bushing isn't a really good option, they often increase the run-out and can allow the bit to slip which is always a problem with spiral bits since the spirals work like a screw thread to try to pull the bit out of the collet.
John White
Shop Manager for Fine Woodworking 1998-2007
I would avoid collet adapters/bushings. They provide opportunity for greater run-out and propensity for the bit to come free at 22000 RPM. This does not make for a fun day in the shop.
I personally try to buy all my router bits in 1/2" shank unless it will be a little used bit or one that is incapable of taking large cutting bites. The design feature of a larger shank bit is it flexes much less; therefore, it will have less run-out. Larger shank bits give a smoother cut.
I standardized so I don't have to purchase a special collet for a few size bits and I don't have to change collets with the bit changes.
Greg
Exo 35:30-35
