Hi All,
What cutting length is most useful for a template bit used in a router. I was considering a 1/2″ shank, 3/4″ dia. Length?
TIA,
Luggage Guy
Good question.. I must have several hundred bits of all kinds. Some 'L' cheapest and many quality bits.
This week I made a template for cutting profiles on some 86 inch long tapered legs for two canopy beds I am making. I had the template made and fitted one of the eight legs to be profiled onto the template. I went looking for a bit. Geeeeee.. I did not have one with a ball bearing at the bottom of the bit! Oh well, back to making a new template to profile the legs.
Unless you only want quality as in expensive bits.. Get a 'set' of bits. I have some 'sets' that were about $50 to $100 US...
As in the 'L' cheapest.. They work for me in most cases.
Get only 1/2 inch shank. I have a few 1`/4 inch shanks hardly ever used. A bit diameter at 1/2 inch will allow a tighter inside radius than a 3/4 inch.
Solid Carbide Spiral are the cats meow but with ball bearings they get really expensive.
EDIT:
A link I found for you. Take it for what it is worth..
Good general information.
http://www.toolstoday.com/t-routerbitglossary.aspx
No! I am not selling anything. Just something I found.
Edited 11/7/2008 10:32 am by WillGeorge
Will,
Did you mean "el cheapo"?Chris @ http://www.flairwoodwork.spaces.live.com
LOL... I never could spell!
MLCS has a shear angle 1/2 X 1 3/16 bit for $13.00 that I use a lot for general work. Also a spiral 1/2" I use on ply, MDF and cranky grain fr $60.00. 1/2" shank won't flex like 1/4" shanks.
Some background and typical options.
It all depends on what you're doing. I help make knock-down kid size rocking chairs. Because the wood is 12mm or 1/2" thick, I put a lot of mileage on a 1/4 and 3/8" diam bits. You have to design your pattern to match the desired results, and that in turn will determin the diam. of the bit you will use.
SawdustSteve Long Island, NY
