I need a pair of round dogs for the 3/4″ dog holes in my new bench. Does anyone have any recommendations about the different types of round dogs available?
Brass – http://www.leevalley.com/wood/page.aspx?c=2&p=31127&cat=1,41637
Wood – http://blogs.popularwoodworking.com/editorsblog/The+Best+Dogs+Are+Mutts.aspx
Nylon – http://www.thewindsorinstitute.com/tools.html
Others?
I’m leaning towards brass dogs, but do they mar your work when pinching between dogs? Can they damage your tools if you strike them accidentally?
A round dog is one that is eating way too much. ;-)
Steel is very strong and durable, brass is almost as good, but looks sexier. Personally, I prefer wooden dogs, replaced as needed.
I used to use wooden ones all the time, then purchased a set of the Lee Valley brass dogs awhile back they work very well for me, I hit the top of one a couple of years ago with a #6 Bench Plane (there was some cussing after that), but when I got looking at the damage and all it did was scrape up the top of the bench dog a bit but did nothing to the plane blade, if you are concerned with marring a finished piece just back it up with some scrap wood. I still use the wooden ones they are the cheapest and they won't mar your finished product. The brass ones you can store in the dog holes in your bench when not in use the wood version usually has to be stored elsewhere. Never tried the nylon ones.Thats just my two cents worth.
Wolfcraft Europe sell plastic (nylon?) square-headed round legged bench dogs. These also come with their tables. The tables are on sale in America but I could not find them listed separately on their website.
Edited 8/4/2009 3:04 pm ET by davcefai
B & D sell something similar -- cheap and effective: http://www.blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=2659
Jim
I will give up woodworking before I buy anything else from B&D in Malta, apart from a vital spare.
I bought a pair of brass ones from Lee Valley a couple of years ago but I still use shop turned ones in oak and maple. They just seem more "friendly" :)
Cheers, Don Don Kondra - Furniture Designer/Maker
I guess this is a vital spare if you own an old workmate ;^) . Mine came out of the ark, but it won't die. Those plastic doodads are sold here anonymously in hardware stores and probably have no link with B & D -- neither have I, these days.
Jim
Cut a hunk of dowel, put a rubber crutch tip on it, drop it into the dog holes,enjoy!
You never leave marks on what you clamp. You never hurt sharp tool edges. Save your money and get the best bench dog I've ever used.
I use 3/4 dowel about 3" long with a 1" piece of 3/4" inside diamater copper pipe glued to one end. This fits snugly into a 3/4" hole in the bench. I have several doz around so there are always several at hand. Easy and quick to make. When I have to plane a thin workpiece all I do is hacksaw off a bit of the copper end.
These do not mark my workpiece.
Ed
Ed,
Right there man!
Bob,
Bench dogs are a thing of the past.
Just use double sided tape.
Mel,
Still muddling about a dogless bench. I don't need no stinkeen dogholes, yet..............
Edited 8/6/2009 11:49 am ET by KiddervilleAcres
HI bw
I use two types of dog, both homemade (though my benchtop holes are 7/8", the principle shouldn't make a difference). Don't make two, make a dozen.
- First type, peg is an almost-loose fit in the hole, dowel with a 1¼" square of (in my case) oak about ½" thick. The peg is glued into a through-hole in the hardwood square, in use the square acts as the stop for the workpiece. This is good because the square turns to orient itself to the surface of the workpiece, whatever shape it is. These are easiest to get out of the benchtop, as they are a loose fit.
- Second type, peg is a tapered piece of softwood, sized so that 1/2-3/4" is exposed above the bench when it is hammered into the hole (no square attachment to these pegs). I used to use round tapered pegs, but found that squared pegs were just as good and much easier to make from scrap board. The tapered pegs have to be persuaded to come out of the benchtop afterword.
I occasionally run into them with a plane or spokeshave, sometimes with a chisel, more especially when working on thin workpieces - no harm to the tool, but the 'bump' gets into the workpiece and if you're on the final finishing, you have to work it out. More often my knuckles suffer from such contact. One advantage of the first type is that you can make custom dogs with a thin square - less than ¼" if you like. These are not as robust as a thick piece, but if they are just shorter than the workpiece board, there's that much less chance of hitting them or having to plane around them.
Hope this helps.
Cheers,
Chris
