I’m constructing an awning. I need to replicate a structural corbel that bears the weight of the awning roof. It will be made of either redwood or cedar. Undecided if it will simply be left to weather naturally or if a colored stain will be applied. Question — After the wood is milled to size and routed to a template is there a way to make it resemble rough lumber? The grain would be extremely raised. Anything more to be done than just wetting it? Thanks in advance.
Scorch the wood with a propane torch and then scrub it with a hand held wire brush moving the brush with the grain. The scorching will break down the softer wood which, when brushed off, will leave a very pronounced grain. Experimenting with some scraps will quickly give you a feel for how to get what you want.
This works best on softwoods with prominent grain and a distinctly different hardness between early and late growth. There will be some darkening of the wood but it will weather out eventually if you don't put a finish on it.
John White
Sand blasting works very well with redwood and cedar. But prictice first.
Bruce S.
If you use John's torch method... do it before you attach the corbel to the structure.
I know it goes without saying, but...
Andy
Master of the Obvious
Thanks to all for the responses. And yes, I've already envisioned the burned up house and firetrucks. So I will use the propane torch in a fire safe area.
