I’m planning to make an intricate fan-shaped fixed (non-opening)replacement window for my 1902 house. Obviously, it’ll be painted, inside and out. It will involve a combination of curved and straight mullions that I plan to make using paired mullion bits on my router table. Is any particular wood best suited to this purpose?
Even if your painting it I would still use a rot resistant wood either ceder or mahogany. Good luck and post a picture when your finished.
Troy
I came across a study of exterior painted wood items done by a Purdue University prof. His conclusion is to use a wood preservative, primer, and two coats of latex paint. The wood presevative is the key. I found it at Ace. A lot of experts say only oil based paint should be used on exterior wood. The study showed no difference in durability between latex and oil. If you use this painting protocol, then the wood type becomes unimportant.
