Replacing the drive belt on De Walt 13′ planer DW735
I was planing some soft pine but blew the fuse to my shed, and lost power to the machine as well – then later stupidly turned the planer back on with plank still in place – some odd sounds from the the machine, and now cutter is not spinning and wood not advancing – I presume that I broke the belt to the cutter. Any other possibilities? Is this something I can repair/replace myself? Many thanks
I have and use this tool as well. I can't imagine that both chains would break at the same time but - under load and a surge could do amazing things - anyway - there is an exploded view with part numbers and the ability to order parts here -
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=22538&typeId=7605&documentId=21151
Like I said there are two chains and they are 5$ apiece. If you know how to use tools I would imagine that you could fix this using the parts diagrams - just be methodical - take photos of the process so it is easier to reverse when it is time to put it back together. I think that you can take the covers off and do it from there without gutting the machine as it is a consumable part.
When I started working on things I would always lay out the parts in the order I took them off in so I could simply start at the end when It was time to put it all together. This takes a lot of room but a 13" planer should only need the kitchen table to be completely laid out.
