I spend most of my time over at Breaktime but decided to come over here for this question. I have several antique dressers that have turned pulls for the drawers. Several of them have the problem of the knob coming off because the screw hole no longer holds the screw well. Whats the best way to repair this? Some thoughts would be go to a larger screw but I think that would be temporary. Another was to drill out the back of the knob and intall a T-nut so that a bolt could be used. This may upset the purists and restorationists though. Your thoughts? Thanks
I've not heard of Goldens molding paste. Is it like an epoxy or wood filler that I would fill the existing hole with and then redrill for the screw? Is Goldens something I would find at Rockler or Woodcraft or HD? Thanks.
Golden's molding paste is an acryliic gel wih pumice powder added for stiffness and thickening. It can be found at some craft stores and artist's suppliers. Michael's has it if there is one of those near you. I believe that Dick Blick carries it online and in some stores. You can check Golden's website at; http://www.goldenpaints.com
Thanks. I'll give it a try.
Hey Rip,
Just drop a dab of yellow glue (or epoxy) into the existing hole and fill hole with wooden toothpick/wooden qtip/bbq skewer or the like (from craft store) and clip off the excess with a pair of dykes. I use a pair of flush-cut dykes from electronics repair from Radio Shack but you can use any pair.
I do this all the time for screw holes that wind up being off for any number of reasons. Works fine and lasts a long time.
Dan
ripmeister,
I have a few pieces of furniture like yours. I just took some tooth picks, dip in glue and shove them in the hole. Re-drill and put the screw back in...I'm sure I'll be cursed in about another hundred years....lol
If the pulls are real antiques and are important to the piece (original and impossible to replace) you could drill out a shallow plug in the back with a forstner bit (use a drill press and sit the pull on a soft surface on a slip-proof rubber pad). Peck at it gently and use a slow speed. In other words try not to do more damage to the pull then you will be fixing, take your time. Plug the hole with a shallow plug of wood and yellow glue. Redrill as needed.
