Has anyone successfully removed the black stains caused by wood boring insects? I’ve tried all kinds of bleach, including 2-part and things like Goof-Off and Goo Gone but no luck.
I've never, fortunately, had to deal with this problem, but have you tried oxalic acid? It's often good for black stains originating from water and iron, but insects I don't know. It's cheap (any good paint or hardward store should have it) and easy.
I have not tried oxalic acid, but I will and I'll let you know how it turns out.
Stains
Two part funiture bleach should do the trick. Are you using new product and one designed for furniture finishers ? Some folks call those insect holes character - maybe the back up plan is to try to incorporate this antique look ?
SA
Yes, that's what I was expecting having read all the advice about it. The one I tried is Circa 1850 2-part wood bleach. They give 2 options, first option is using a blend of part A and part B and the second option is to sequentially use part A and then part B. But neither approach worked. I do agree that most blemishes such as knot holes add great character but these worm holes look more like ink stains than anything else. I will try oxalic acid next and let you know.
Bleach
c.1850 - well that's 19th century anyway - product should be OK. dates from your childhood I'd guess
The best way I found to bleach is to use one part at a time and put the second part on shortly after applying the first part -
The oxalic acid is a good product - worth trying - remember to wear a mask if dry crystals are in the air when sanding. Is it possible to drill and fill the insect holes with plugs from the underside ?
SA
