Relay outlet for multi tool power supply
I am hoping someone can tell me were one can purchase these relay outlets (2) with power cord. These are the outlets you plug a table saw or router or chopsaw into the one label direct power, plug a shop vac into the other outlet place switch in on postion and when the saw or router is in use the another outlet that will then power up turning the shop vac on. Turn saw off vac is off to.
Paul C.
Sears.
Thanks Jamie, I'll stop at Sears.
Paul C.
Such a unit is available at http://www.eagleamerica.com Part # 489-8130
It has a delay of 7 seconds before the shop vac or dust collector shuts off
Bruce S.
Thank you very much Bruce, I'll check out eagle america.com.
Paul C
Woodcraft just started stocking them; don't know how the price ($34.99**) compares:
http://woodcraft.com/family.aspx?familyid=5855
I use a swtich-activated box (like you'd put on a router table) with a heavy-duty 3-outlet tap added. Not as clean, but way cheaper. Same number of amps. If I want a 7-second delay, just have to stop feeding wood and count to 7.
**Same brand as the Eagle, $5 less.
Edited 10/11/2006 12:26 pm by forestgirl
