Hello Peter,
My son just purchased a house where in the library, a number of pictures and photos were hung on the paneling. Over the years, the sun has bleached out the paneling where nothing was on the wall. The paneling is about 30 years old. It is 3/4″ x 6″ pine planks. The wood was stained and has a low sheen, so I assume miminal sealer was applied. We would like to restore the paneling to a uniform finish.
Any suggestions?
Thank You
thogan,
I think the best thing you could do is to refinish it. If the finish is really minimal, I would suggest you sanded it well.
Pine is soft enough to sand very easily. The first sanding will probably clog the paper fairly quickly as the finish comes off. The second sanding will refine it. You'll have to decide what works best as far a grits of sandpaper are concerned. If 150 isn't quite cutting it, drop down to 120. Follow it up with 150 and a light once over with 180.
You didn't say what your plans for finishing are. If you plan on staining, it will help the various areas blend together. ( if they are in any way still prominent)
The other way is to spot sand the darker areas. This can be a little tricky at times.
If you have the time and space, do it right from the start. When you kick back in there, you'll really appreciate all your efforts.
What are you planning for the finish?
Peter
Peter:
Thanks for your reply. I think I want to apply an oil finish (linseed oil, danish oil etc). The wood is just beautiful and it makes the room look great. I don't want to take away from its character, so I'll spend whatever time is required to do it right
Tom
