Hi everyone!
Would someone please recommend a book on how to refinish or restoring an old piano?
THANKS!
Fine Woodworking Recommended Products
Whiteside 9500 Solid Brass Router Inlay Router Bit Set
Set includes solid carbide down-cut spiral bit (for chip-free cutting), quick-change bushing, template guide and complete instructions. Fits Porter-Cable, Black & Decker and any router with a Porter-Cable bushing adapter.
Amana 46577 1/4-in. Up-Cut Spiral Bit
Diameter: 1/4
Cutting Height: 1-1/2
Overall Length (L): 3
Surface Coating: Spektra
MicroJig Grr-ripper2 Go
Introducing the Grr-ripper2 Go from Microjig! This innovative tool protects your hands and fingers from cuts and injuries while working with the table saw.
Starrett 12-in. combination square
This accurate, robust, well-machined, easy-to-read combo square is as great as ever.
Jet JWJ-8HH Helical Head 8-In. Jointer
This machine joints a very good surface, with a fence that is flat and smooth-moving. The fence is easy to set to 90°, and it stayed that way. The 90° stop was also easy to set and reliable. The start and stop buttons can be installed above or below the infeed table.
A few years ago in FWW there was a lengthy article about finishing a piano. Do a search and you may find it.
You could also get in touch with Jeff Jewitt at http://www.homesteadfinishing.com and pick his brain.
Tom,
THANK YOU for the link. I own a couple of Jeff Jewitt books but I didn't know about this site! I'll post a message and see what happens!
THANKS again!
