I need to duplicate a very reddish finish on some quarter sawn white oak. I’ve done some test pieces with med and dark walnut Watco first coats and then cherry Watco on top. It’s not nearly red enough, nor is straight cherry Watco. I’m about ready to try some analine mahogany or early American cherry aniline.
Anybody have some other ideas on this? Thanks.
Alan & Lynette Mikkelsen, Mountain View Farm, est. 1934, Gardens & Fine Woodworking, St. Ignatius, MT
Can you post a picture of the piece your trying to match. Its hard to offer advice without seeing a picture.
But Trans tints work very well at trying to match colors, there easy to tweak to match just right.
I just used an exterior stain on some white oak tables I built for outdoors which is pretty red - it was Mahogany Flame - Australian Timber Oil by Cabot.
Try some Minwax Red Oak stain. I just finished a computer desk with it and it came out gorgeous. It's a highly pigminted stain that can give you anything from pink to black - depending on how long you let it sit.
I put it on with a foam brush and let it sit for several minutes, then used the brush to gently wipe off the excess - blotting it on a paper towel. I kept working with until it "squeaked" slightly when I brushed it, then let it sit and dry.
See the pictures in the Gallery - Daughters Xmas Present.
Agreed !
Alan,
I have a few bottles of Trans Tint and use a Rob Millard suggested idea. I spray and wipe the red-brown trans tint using water to give a red undertone....obviously, I can vary the strength to change the intensity...
Thanks all. I think i'm going to go with a gel stain, probably Bartley's Pennsylvania Cherry.Alan & Lynette Mikkelsen, Mountain View Farm, est. 1934, Gardens & Fine Woodworking, St. Ignatius, MT
Hi Alan,
It's a tough question to answer without seeing what you're trying to match.
That said, almost all of my QSWO mission furniture has a pretty warm tone to it...achieved with Vintage Maple Transtint followed by 2-6 coats of dewaxed garnet shellac.
The garnet shellac is what ultimately warms it up..I then use some very dark gel stain as a pore-filler and top with sprayed clear nitrocellulose and semi-gloss poly on the table tops.
See my stuff at: http://www.kesslercraftsman.com
Good luck and experiment with scraps..making sure to do the whole finishing schedule before deciding..every step counts!!
lp
If you are trying to match an existing piece, a professional paint store can be a big help. If I can remove a piece of the original, a door or a shelf. I'll take that and some scrap wood to the paint shop and they will use a color scanner. They mix a stain that will be closer than I can come up with after much trial and error. The service is usually free.
TRY THE BEHLEN MASTER RED MAHOGANY -COMES IN 3 COLORS-TONES OF RED -LIGHT TO DARK. IF YOU WANT A BRIGHT CHERRY-RED APPLY THIER ORANGE MAPLE UNDERNEATH-BE CAREFUL WITH THE ORANGE OTHERWISE YOUR WORK WILL LOOK LIKE THE PAINT JOB ON A TRICKED-UP '57 CHEVY. THE STAIN DRIES IN AN HOUR AND WORKS WITH MOST FINNISHES.
