1-Can one use a cove raised panel with an ogee rail and stile prfile?
2- I am building kitchen cabinets with inset doors. I woul like to use conceiled hinges for the ease of adjustment instead of hinges. Is this a bad idea and will it look not so hot with out the classic butt hinge w/finial
-Thanks Lou
No problem, You can mix & match any panel profile to any S/R profile you like. Actually I like the cove panel with the Ogee S/R.
No problem again, It's a matter of personal taste on the hinges. The Euro style hinges give a much nicer and cleaner look, again it's personal taste.
Go for what you like .
Bruce S.
Hi Lou ,
For flush inset doors the Euro hinges are a dream , I make the door 3/16" shy width and height they fit perfect every time .
The stile and rail detail do not have to be identical at all .
good luck dusty
