OK Dumb question. I have a stick of Ebony that is covered in wax I want to slice some of it up for some detail inlay in a box I am making for the OYMO. Can I just Cut it or will the WAX contaminate my BS and such? Should I scrape it off?
–DUCT Tape is the “force”… It has a Light side and a Dark side and it binds the universe together
Rich,
I made the mistake of being lazy and feeding wax-coated lignum vitae through my planer a few months ago and gummed up the bed and rollers. If the wax is only on the end, or if you don't care about getting wax on the table (easy to clean off with mineral spirits), go for it. When I started making my lignum vitae plane, the first step was to scrape the wax off the surface with a card scraper. I don't think the wax would hurt the blade. It might even be good.
As mentioned, scrape it off. I've resawed both ebony and african blackwood. Be prepaired for a mess and a pitched up blade.
Bruce S.
Thanks for the reply's. Ill Scrape it down.RichCapt. Rich Clark
--DUCT Tape is the "force"... It has a Light side and a Dark side and it binds the universe together
There's another consideration. Much of the "dip-waxed" exotics are so-called "air-dried", which means it isn't (dried, that is). Much of the wood that I've bought in this condition is very wet, and will warp, check, and do the watusi when cut into smaller pieces. The only solution I've found is to scrape the wax off with a card scraper and wait a few months for it to dry out. I've measured a few "turning blanks" of ebony and rosewood treated this way by weighing it over the course of several months, and found it to have as high as 19% moisture content.
