FYI — The Mar/Apr 2009 issue of Home Shop Machinist Magazine has an article on building a router table that offers machine shop accuracy to woodworkers. It may be a worthwhile read for those who have machining capability to create the fence adjusting mechanism or as a starting point for your own design.
Mr. Gavin, the author, makes the statement “no currently available router tables, to my knowledge, offer the capability of adjusting the fence position relative to the router bit in thousandths of an inch.” But that capability does exist in several designs that have been on the market for several years. I’m not sure if that speaks to the author’s lack of research (perhaps he is not online) or the ineffectiveness of the marketing reach of major players in the industry like INCRA, Jointech, and Kreg. Then there are Pat Warner with his micro adjustable fence designs, and Lewis Strepp of Craftsman Gallery who put DRO on the Woodrat at a very affordable price.
I do applaud Mr. Gavin for a simple design that I would modify if I wanted that capability and did not have my Incra LS Positioner.
Greg
Exo 35:30-35
Greg,
Evidently, Mr. Gavin is not really aware of the available options in Router Table fences. For instance, the Freud SH-5 has been around for several years and is infinitely adjustable with increments in thousandths of an inch for both the infeed and outfeed fences:
http://www.freudtools.com/p-269-sh-5-premium-router-tablebr-fence-system.aspx
Freud America, Inc.
Charles,Nice to see you back.Cheers,Peter
Better life through Zoodles and poutine...
Hi Peter,Thanks, I've never really gone away. I check the forum daily but only post if I feel I have something of value to contribute.
Charles M
Freud America, Inc.
I believe he is not aware that many products are capable of maintaining tight tolerances.But Charles, I was not aware of your product either. I recently bought an INCRA system. I looked at several options for months and did not know FREUD made a fence. I have FREUD products, but have not seen any advertising by FREUD on this product. I asked participants on several forums for recommendations. I did searches on Google. It never once revealed a FREUD fence.Greg
Exo 35:30-35<!---->
Greg,Thanks for the info. I'll let the marketing folks know they're missing opportunities.
Charles M
Freud America, Inc.
Greg,
LOL LOL.. I worked in Service and Marketing for many years. All I can remember is the bosses ALWAYS listened to the marketing folks if if they (I?) was wrong?
I have NOT looked at your link (at the moment, I will after my comment) OR any other words posted here.
Been using my routers and router tables for many, many years. IF the router is working off a flat surface, THAT means everything in my blind eye!
I would say the fence can be a hunk of 2 by 6 pine 'IF' it is straight along the length and 90 degrees to the table surface.. ( I corrected my typing ) I admit, I first typed 45 degrees to the table.. :>)... And corrected it. But then again many uses for a angled fence.
AND there is NOTHING! WRONG WITH A FANCY AND ACCURATE fence. GO FOR IT!
Will, You are correct about a fence. Craftsmen have made fine works for years without a micro-adjustable fence for a table. But one such fence or system of adjustment and repeatability does give us so many more control options than a "perfectly straight" 2x6 can offer.The fence designs like those of Pat Warner, Incra, and apparently FREUD offer a way to make adjustment without the old trial and error way. That is, with the 2x6 pine board clamped to the top, you have to bang one end with your hand until you generally go a little too far, then you bang it back. Eventually one arrives at a close enough position. Try to set that same fence setting tomorrow or a month from now.With several of the other systems, you can come back next hour or next month and reset the fence in the exact position it was in with respect to either the bit center or the bit cutting edge. "Exact" here means within such close tolerance that the cut feels and appear identical.Greg
Exo 35:30-35<!---->
