I am interested in the experiences others have had with powered respirators. I have been using a half face mask when sanding and find it eliminates the tickling cough that would otherwise develop. It feels like I am breathing good clear air. However I have a beard and I have read that substantial amounts of air are passing between mask and face.
Thanks.
I have used a "powered respirator" for years when I do lathe work. They (mine) are excellent. There is a rubber skirt at the bottom that does not fit tightly, therefore should work OK over a beard. The flow of fresh air from the top down is refreshing.
Frosty
OSHA's respiratory protection standard (29 CFR 1910.134) specifies certain requirements for employers to follow when their employees must wear respirators. The standard states that the employer cannot permit respirators with tight-fitting facepieces to be worn by employees who have facial hair that comes between the sealing surface of the facepiece and the face, or that interferes with valve function. While the standard does not ban beards per se, it does require employers to ensure that bearded employees who are required to wear tight-fitOSHA's respiratory protection standard (29 CFR 1910.134) specifies certain requirements for employers to follow when their employees must wear respirators. The standard states that the employer cannot permit respirators with tight-fitting facepieces to be worn by employees who have facial hair that comes between the sealing surface of the facepiece and the face, or that interferes with valve function. While the standard does not ban beards per se, it does require employers to ensure that bearded employees who are required to wear tight-fitting facepieces trim their beards so that they do not interfere with the sealing surface of the respirator or are not so large that they could interfere with valve function.
This may answer you question about using half face respirators. Wiskers arn't much of a filter ;-)
A powered positive pressure mask is the way to go.
Bruce S.
Edited 1/2/2009 9:43 am ET by BruceS
Bruce,
You are right in what you say, but let me tell you about something I saw a long time ago.
When I was a GI we trained with the Dutch soldiers. We were clean shaven, but they all had big, full, bushy beards. They wore US gas masks just like us.
When we would have gas training they never had any problems getting a gas mask to seal over those big beards.
I always wondered about that years later when the OSHA reg went into effect. One guy I know still thinks that the OSHA Secretary's wife ran away with a bearded guy. So the reg went into effect to punish those with facial hair...
Happy New Year
Fred
Prior to retirement I was an airline captain. The (north american)company forbade us to grow a beard on that same basis (oxygen masks in case of decompression). However it was noted that a number of other first world airlines had no such restriction. Turns out that there are masks out there that are certified for beards under a certain length. Turns out it was just a matter of PR for the management.Cheers,Peter
Better life through Zoodles and poutine...
