Does anyone have the porter cable pocket hole cutter machine and do you know if it can be modified to accept thicker material than 15/16″. I want to use it for face frame joints, and I tipically make my frames 1 1/16″ thick. The only other machine I considered is the Castle machine but it’s to expensive for my small shop.
Fine Woodworking Recommended Products
Craftsman CMEW213 Belt Sander
Weight: 6.6 lb. Amps: 7 Variable speed: No Belt alignment: Poor Material removal rate: Poor Sanding flatness: Poor Shaping/scribing: Poor Handling on side: Excellent Dust collection with hose: N/A
Next Wave CNC’s Shark RS1000 Pro
Next Wave CNC’s Shark RS1000 Pro allows you to adjust your router’s bit height and fence placement with computer-level accuracy. The software accepts imperial, metric, decimal, and fractional measurements. It also has preloaded applications for common functions like box joints, dovetails, and dadoes.
- Initial static pressure (in. of water): 77 - Static pressure with bag 2/3 full: 75 - Noise level (db): 80 - Disposable filter bags (5 pack): $70 - Reusable bag avail. from mfr.: No - Hose length (ft): 13.5 - Cord length (ft): 24
Shop Fox W1826
The thick, felted bag on this Shop Fox is a plus and a minus. On one hand, it makes the unit much less expensive than collectors with canister filters, and also lighter and easier to hang on the wall. Without a separate plastic bag to catch chips, however, they stay in the felt bag, and the shortish zipper on the bottom makes it tough to shake them out. Otherwise, the W1826 is an excellent value.
Makita 9903 Belt Sander
Weight: 9.5 lb. Amps: 8.8 Variable speed: Yes Belt alignment: Excellent Material removal rate: Very good Sanding flatness: Excellent Shaping/scribing: Very good Handling on side: Fair Dust collection with hose: Fair
A friend of mine has had a air powered krieg jig model for the past 4 years and loves it. I have used it and the porter cable/router model and I by far prefer the Kreig brand.
I agree with Migraine. I have used the Porter Cable pocket hole machine and I own the Kreg. I much perfer the Kreg. With the Porter Cable you have a router and a drill motor. With the Kreg all you have is the drill motor operated by air. The Kreg will accept thicker material than the Porter Cable. I believe it is up to 2"???
Hope this helps,
