Is it an absolute no-no to run some pine doors that have been polyurethaned thru a Makita 2012 planer? I know it’ll probably gum up the blades but will it damage the rollers etc?
Thanks much!
Thanks much!
Assuming the varnish has cured it won't really hurt anything. The varnish doesn't even have the abrasive properties that some paints would have.
Might be a good idea to go easy and not let the planer get hot.
I have run wood that had been finished through the planer and it did not seem to cause any problem. I don't know if anybody has done any real tests to compare the ware rates on the blades but I don't think you will have any problems as long as the finish is cured. Let us know how it goes.
Troy
knotty ,
Is all the grain running the same way or are they frame and panel doors ?
dusty
Fortunately, these are not panel doors, they are one piece and the grain is in the right direction. They are on a computer desk I built. The doors are a bit warped and it would look a hellovalot better if they weren't. I'll let you know when I'm done what happened. The blades on the machine has a knick in it so I was going to sacrifice it anyway. Thanks for all of the input, I love this site!
Two things , if the doors are warped now , they likely will be thinner but still warped after planing .It will not make them flat only thinner
Not knowing what type of planer you have , if one knife has a nick simply slide that one knife over a tad and it will erase the nick in the wood .
dusty
Hi Thanks for writing. I'll try that trick with the blade knick. As far as taking the warp out of the door. It is curled along the grain direction edges. I thought if I take down the the curves with a jointer first to get them close, the planer would finish the job. No? I wish I could draw you a sketch. Wich reminds me, I just started using Google Sketch Up and it's not bad. It's easier than Acad, not as complex in 3-D. There'll be a learning curve for sure though. I'm using a Makita 2012 BTW. Looking at them, the curle isn't that bad, I'd just like a second shot at routing the face. Thanks again, I'll let you know what happens.
Hello and a happy fourth of July to you (Independence Day). I just wanted to let you know that I did flatten one of the doors today and I'm pleased with the results. Although a bit thinner it is nearly perfectly flat now and the grain shows through nicer too. I hit the edges with a flush trim bit first to get some of the warp out. The Makita planer worked like a champ too. It's good to know I can strip a finish and re-do it if necessary (as long as it's < 12"). Also, the little gouge the blades were leavings seems to have magically disappeared too. Thanks again, be carefull with any fireworks this weekend.
