Where can I order a piece suitable for a router table top insert. I can do my own drilling, etc., I just need the laminate sheet.
TIA,
Harry
Edited 3/31/2008 4:42 pm by harrycu
TIA,
Harry
Harry,
If I'm not mistaken, phenolic is off the market. I don't recall why. You can still buy baseplates made of phenolic though.
Chris @ flairwoodworks
Well...I found places on the internet where I could buy 4'X8" sheets of it in just about any thickness I desired, but no pieces small enough for a router table.
No matter, though, I found one at Amazon they call an insert blank. The center hole is predrilled at 3.6" I think but the mounting holes will have to be drilled. This insert usually sells for 30 bucks and it was on sale for $11 and change.
Thanks,Harry
Following the path of least resistance makes rivers and men crooked.
Edited 3/31/2008 8:34 pm by harrycu
I know that Veritas sells a phenolic baseplate/table insert. 05J2501.Chris @ flairwoodworks
Call a local toilet partition guy. There's probably some scraps laying around."How do you spell illiterate?"
Those are usually polyethylene or polypropylene, not phenolic.
Check out Woodpeckers (http://www.woodpeck.com).
Frosty
All I found at Woodpeckers' is the inserts.
Thanks,Harry
Ebay.
Thanks, hadn't thought of that...
Harry
Phenolic resin is a glue that when impregnated into a fabric or paper creates a very tough slick and stable material. Formica and melamine are phenolic based materials. What you are actually looking for is something like a plywood with a laminate surface on it or a sheet material made up of layers of fabric or paper bonded by the resin.
For the sheet material form go to mscdirect.com, they're a machinists supply house and have pages of laminates to choose from. They are an excellent company to deal with and deliver very quickly.
John White
