I just picked up a Parks Planer it was free,now i have to invest some time in cleaning and fine tuning it.I know there was a website on fww about restoring Parks Planers can someone help.The machine was purchased at Rudolf Bass 173-7 Lafayette Street N.Y. City Ser. #1747-1 Motor Dayton Electric Co.( Model 6k338) (HP.1-1/2) ( RPM 3450) ( Duty Cont.) Rise-40 ( Max Amps 40) Its built like a tank.
woody, I never thought I would hear the name of R. Bass again, WOW!
As a kid in the mid 50's I was gifted a Rockwell 10" band saw that needed tires. It was my first entry into big time ww tools ha ha and I was overwhelmed in this old crusty place, not in the best part of town--all business -- and not Park ave. bankers. It cost me $2.25 each -a fortune- plus the subway fare all the way from Brooklyn. I walked in with the yellowed instruction sheet dated the same year I was born 1942, he looked at it with almost contempt walked down the parts aisle and threw two black rubber bands on the counter and said "and what else do you want? " I paid with two bills and the rest in silver.
Had I been smarter I would have bought the bearings which are open cage balls on hardened races that are missing several balls. Now I know that I can source the balls and WILL refit this little saw. Thanks for the memory. Paddy
I remember Rudolf Bass store it was on the corner,and i to took the train from Brooklyn. I now live in Breezy Point how about you.
wood,
I have a Parks planer that I bought new in 1975. It is a little workhorse. Anything I can do to help with specific questions, let me know.
the Old Woodworking Machines website may have the rehab info you need. I think their site is OWWM.com
Thanks i will try that web site.
Can you tell me what type of lubrication you use in the gear box and where i can purchase it? I was told that this planer was manufactured `1938-1942.
wooden,
My literature says to use 1/2- 1 lb of soft pressure gun grease, as available in auto garages, in the gear case. It's available at places like Autozone, Advance Auto, NAPA, or in the auto care section at Wal-mart. Use the same grease on the bearings at either end of the cutterhead (alemite fittings) and on the motor if it has the fittings there. The feed rollers and bed rollers (bronze bushings) are lubed with 30 wt motor oil.
Your machine may be that old. They were mfd at least into the late 70's early 80's as far as I know. My price list is dated March 1976, when I bought the machine. My literature shows the basic 12" planer as the model 95- no motor or base, model 96 has the motor directly attached to the end of the cutterhead, model 97 has a base with motor driving a pulley on the end of the cutterhead.
Thanks i will pick up the grease today.
wooden,
You're welcome. Good luck with your planer.
http://www.owwm.com/mfgIndex/detail.aspx?id=618 is a great source for info. Go to http://www.OWWM.Org and register, this is the discussion forum, the knowledge base there is incredible. It can be a great help during the restoration process.
The owwm.org (forum) site currently has a photo essay on a Parks restoration. The guy did a beautiful job on it. I picked up a Parks last summer and the info I needed to get mine running was on the site. My parks needed a bigger motor, proper size pulleys and belts, and a few minor adjustments. This thing will hog off 1/8" of white oak 12" wide without a hiccup.
There's an excellent article in FWW from the 1980's or early 90's entitled something like "Tune up your Planer". The author demonstrates using a Parks Planer. He also shows how to make several jigs which help with the tune-up. If you do a search, you should be able to find the article. My Powermatic 12" planer is very similar to the Parks and I used the article to tune up my planer when I bought it used a few years back.
Chip
