Anybody use them? They don’t seem to be widely distributed and, IMOO they make a miserable, awful, finger-bashing-bad-job-so-we’ll-deal-with-raggedy-cuts-for-another-year task into a merely not-fun task. I can’t believe I waited so long.
Oh, and one more thing, when I’m declared god of contractor saws, I’m going to include an access port for at least one front trunnion bolt…
Fine Woodworking Recommended Products
French Curves
An essential for drawing and designing with curves.
Bahco Camping Axe
Total Length: 14.2 inches (360 mm) Blade Length: 4.3 inches (110 mm) Weight: 2.8 oz (800 g) Material: Tool Steel
Leigh D4R Pro
The D4R Pro is Leigh’s flagship jig. Like the other Leigh jigs in our test, it represents a different world of quality, from its clear, comprehensive instructions to its ingenious engineering, impeccable manufacturing, and unmatched capabilities.
Veritas Micro-Adjust Wheel Marking Gauge
The adjuster runs through the beam from a small knob at the back end right to the cutting wheel, which moves in and out as you turn the knob. This arrangement works well but makes adjustments a two-handed operation, requiring a little more effort.
Makita 9903 Belt Sander
Weight: 9.5 lb. Amps: 8.8 Variable speed: Yes Belt alignment: Excellent Material removal rate: Very good Sanding flatness: Excellent Shaping/scribing: Very good Handling on side: Fair Dust collection with hose: Fair
I used to have a Craftsman contractor TS that I installed a set on. They do make fine-tuning the adjustment easier. However - at least on the model sold to fit the Craftsman, once the setting was dialed in you'd have to remove the rearward adjuster. Otherwise it interfered with the blade-tilt mechanism. You could tighten things down before removing it and putting the factory hardware back in place, so your adjustment efforts weren't wasted. It's just that you couldn't leave the rearward portion permanently mounted on the saw - unless you didn't plan on ever making a bevel cut.
Take a look at the new Ridgid contractor's saw in HD the next time you get there. You don't have to wait until you run the world, the adjustment problem has already been solved.
Ridgid redesigned the saw to make blade to table alignment an easy 5 minute job, accurate to a couple of thousandths, simply by adding two bolts and a little cam lever. They also added a lock to the front trunnion and a spring loaded clamp to the rear trunnion so each trunnion assembly will stay fully engaged while the alignment is being adjusted.
I can't believe it took 50 years for someone to make this simple change on contractor's type saws.
John W.
The PALS--costs $2 to make; they sell for $20, and are worth $200.Regards,
Boris"Sir, I may be drunk, but you're crazy, and I'll be sober tomorrow" -- WC Fields, "Its a Gift" 1934
Has anyone had trouble installing the PALS system? I have some vague memory of one report, but as Ed says, not too many of these in use it seems. When I got my old blue Jet saw, it was out of alignment to an alarming degree and I only made it worse trying to fix it. Ended up having to get a Jet tech guy to solve the problem. Am very nervous about the idea of loosening anything under there again, but the PALS would be a welcome improvement in the long run.
"I'm going to include an access port for at least one front trunnion bolt..." Hmmmmmm, given how old my saw is, I might just make an "access port" LOL!
I installed them recently on my Delta Contractor Saw (20+ years old). They worked great. Following the directions I replaced one of the existing trunnion bolts at a time with a stud. I installed the PALS and had no trouble re-aligning my saw. I used a dial indicator and a Master Plate on the arbor flange. The saw has never worked better. I highly recommend the PALS.
BTW, be sure to tighten the nuts on the studs and add a locking nut to each - you don't want the trunnion moving around due to vibration.
