Neighbors bought a pine board with their name routered in it- He wants to clear coat the board, and paint the letters a dark color, and asked if that was a good idea- I said I reckon so- I told him the poly wouldn’t hold up in the sun, but that paint would probably adhere to it okay- Any ideas about how best to finish this sign? Thanks for any ideas or experience-
Poly will not adhere well to paint unless the paint is fully dry and it has been scuff sanded with 220 paper.
You are correct, most polyurethane finishes do not stand up well in direct sunlight.
Precisely what I told him- I must be smarter than I thought! Much obliged-
The reverse would be equally valid... scuff the poly before painting over it.
Instead of regular poly, you can use spar urethane or spar varnish, the stuff used on the woodwork of fancy yachts. It has UV inhibitors, Sun and marine exposure is pretty rough on boats. Need multiple coats, and depending on the situation and extra coat or two every couple years.
If sanding isn't practical, use a good quality enamel undercoater (special primer) over a smooth surface and under paint. The good stuff sticks to glass.
You couldn't put a name to that "special primer", could you? Much obliged-
All/most of the good paint manufacturers make such a product. I've been using Behr (latex, purple can) for many years with goods results, but just noticed it is only for interior.
Here's one for exterior
http://www.ppg.com/ppgaf/pittsburgh/sealgrip/index.html
Yellow can, alkyd (oil). Other makers (BM...) probaly have a similar product, visit a local supplier. Or a marine/boating store.
In you case, gently scuffing the letters using an abrasive pad (brown), then covering with the undercoater should result in the best prep before painting them.
Thanks very much- Again!
