A client has asked me to build a sink cabinet to go on their screened in porch. It is a paint-grade piece but has significant furiture details. The area has moderate winter and humid summers. Any suggestions on construction/materials?
If water can get at it, marine plywood would prevent delamination.
A latex finish coat offers more flexibility for wood movement.
mhefner,
You might consider rolling on a coat or two of epoxy before you paint. Completely encapsulating the wood with epoxy will prevent any moisture getting to the wood, and that prevents all wood movement from changes in its moisture content. Sealing the wood prevents most of the problems associated with outdoor structures; and keeping the wood dry will make it last much longer.
N.B., the wood has to be completely covered by epoxy for this to work. Each and every tiny bit has to be coated. This isn't very difficult, but it does require close attention to what you're doing.
Alan
The abbreviation "N.B." isn't seen much in the States. Are you by any chance from across the pond?
Waynel5,
Nope. Home born and bred in the USofA.
N.B. is used quite a bit in academia--or it was in my field. It's too bad such a useful abbreviation is used so little elsewhere.
Alan
I've built outdoor cabinets out of MDO edged in ipe that have held up outdoors directly exposed to the weather.
