I would like to make my next wooden plane out of this wood which I believe is osage orange. I am not certain that it is, but it looks like it may be just that. I also do not remember where this log came from, which is not much help either.
Comments welcome as always.
Sure looks like it, should be rather heavy. You can put a few shavings in water and the water should turn yellow.
Sorry for the late reply, but I thought I was set to receive posts. Guess knot. :-))
I also just received an 'Access Denied' message. Anyway, ...
I did as you suggested and soaked a handful of jointer shavings in water for a few days. Does the image look the 'yellow' you had envisioned?
I don't know of another species that has a yellow dye that will leach out in water like osage orange. If a few shavings turned that water yellow, I'd bet it was osage orange. In about 5 yrs. it will turn chocolate brown, then you'll know for sure.
That looks more like yellow locust than osage orange to me, if the color is true in the picture.
I have made a plane out of osage orange, and it seems to be pretty stable. the piece of firewood I worked it out of was pretty well seasoned, and the stock was quartersawn, well, quarter-split to be precise.
Phillip,
Colorwise, locust is more a pale yellow- green in color, while osage orange is more yellow to orange. Osage orange burns hot, like locust, but while locust burns down quietly into a bed of hot long-lasting coals, osage orange constantly pops and throws sparks and embers like crazy. It's impossible to safely burn it in a fireplace, and opening a stove door is the same as setting off a fireworks display.
I don't know anything about how stable locust might be for a plane, I have an old, shop-made smoother that I think is locust, but it is a relic, not a user, I've never tried to recondition it to try it out. It is plenty hard enough to wear well, I'd think.
