Okay, here’s what I’ve got:
Finishing a walnut bookcase, sanded the whole thing to 320, applied a coat of boiled linseed oil, and buffed off the excess after 10 minutes. That was Saturday (5 days ago).
My next step is to start wiping (padding) on garnet shellac. Here’s my question-
The BLO seems to have raised the grain a little bit. Should I:
1. Steel wool/grey abrasive pad over the case before padding on shellac
2. wipe on 2 or three coats of shellac consecutively and then block sand with 320 or 400 before continuing on with rest of shellac coats
3. do both of those
what do you say?
Kevin
Kevin,
The most important thing, I'm just leaning this, is to follow one and only one protocol...or process. From the options you've listed I'd pick #3 (using soapy water and 400 grit)...and rub out each and every coat after that to reach the desired finish....could be many many coats. Also, you may want to step away from the garnet after the first coat and go to blonde or clear...it's up to you
I'd just use some 320 to smooth the surface before starting in with the shellac. You should always do a sample first to work out the steps in advance in case there's any problems. Personally, I would have skipped the BLO, but try a sample with and one without to see what you think.
Paul
Thanks- I did 4 seperate test pieces, and the one that everyone liked the most (me included) was 1 coat of BLO with several coats of wiped on garnet shellac. The BLO really gave the walnut a richer, deeper brown color than the piece with just garnet shellac. Straight garnet left the walnut still looking ever so slightly greenish-grey, or maybe I should say washed-out. Not that I'm an expert on walnut but I suspect it's the nature of kiln-dried and also VC ply walnut.
I've thought about the blond shellac, and I do have some flakes ready, so if it's getting too dark and I'm not happy with film thickness yet, I'll top it off with some blond shellac.
Thanks for the feedback from both of you, I just wasn't sure if I should let the shellac capture the nibs of raised grain before sanding. I'll smooth it out tonight, and I hope I can get started on the shellac Saturday morning.
