I’ve been making wood bodied handplanes using old, “worn out” files and lathe chisels. Usually I make either a “V” shape or a cove shape plane out of these. I’ve also made a “chisel plane” that uses a 1/2″ wide chisel. Most of these are made to use with the “bevel” down. Wood for these planes comes from scrap maple and beech. If I can get a couple pictures to post, I’ll post later. So, don’t throw away those old files and lathe chisels, they COULD be your next hand plane.
Looking forward to it...
and www.flairwoodwork.spaces.live.com)
If I got this right, here are two of my home made planes:
Screwing on the bar (for lack of a better term) makes it easy. Nice and simple. If it were me, I'd probably have done it the hard way and shaped the body from a single piece. Where's the "obligitory" photo of the plane making a see-through shaving? Just bugging you.Chris @ http://www.flairwoodworks.com and http://www.flairwoodwork.spaces.live.com)
There is a "side-bar" on each side. It gives a better "grip". The first one is about 1" wide, and gives a "hollow" profile of about 1/4" deep. The second one gives a "V" shape, and is about 3/8" wide. Working on making a "rounds" profile plane. I can clamp a straight-edge to the work (or the planes) to "guide" the cuts. The "chisel plane" is also made like these. I use it to clean up rabates and dados. It uses a 1/2" wide chisel, bevel down. They don't give the "paper-thin" shavings, yet. I've used some of these as a "panel-raiser" after cutting away the "waste" with a dado blade. They ain't bad.
"It uses a 1/2" wide chisel, bevel down. They don't give the "paper-thin" shavings, yet."
Why not? Ordinary files are made from high carbon steel and will hold an edge much the same as O1 as long as you have not lost temper by over heating when shaping the end.
What are you using to shape the ends and remove the teeth? (very good application for a belt grinder here which will remove metal and teeth on files chop chop without too much heat either).Philip Marcou
I just have a "regular" grinder. Shavings are close to paper thin. On the "V" groover, not looking for paper thin, same as the other "profile planes" I have. The chisel for the "chisel plane" does need a bit of sharpening. But for cleaning up tenons, dados and other 'grooves" it works just fine. I did make "holders" for these planes. Just a "U" shaped jig, made of three pieces of 1x3 scraps. Those side pieces rest on top with the "business end" not touching the bottom of the holder. Old "Blue Diamond" files, teeth almost gone. This gives them a new lease on life. Plus, the "price" is right. $.00!
Yes, I reckon that old files are under appreciated by woodworms. This is aggravated by that cyber myth mantra which says that they just shatter and kill you if you use them for anything except filing. They make great turning tools. For those with black smithing ability they are a source of free steel to make all kinds of things.
But we must be careful: just now there will admonitions from on high which decree: THOU SHALT NOT PLAY WITH OR MAKE TOOLS-THOU SHALT AT ALL TIMES WORK WOOD (BY HAND) ONLY. Strangely, these words (or similar) often come from those who denigrate high cost planes etc. I digress, maybe I should get to grip with my own blog.Philip Marcou
"Yes, I reckon that old files are under appreciated by woodworms."Philip,I might guess that old files are OVER-appreciated by woodworkers. That is, we keep using them and using them and using them well after they are worn out. I'm guilty of that.Chris @ http://www.flairwoodworks.com and http://www.flairwoodwork.spaces.live.com)
You might be right.....but I am impatient with files, much like sand paper- they work nicely for a short part of their life -after that I want a new one....Philip Marcou
Now you know what to do with the "old" files. It's a lot more fun than "deleting" old files. Now, IF I can figure out how to use all those "half-round" files I've got. I've also got one that has SIX sides! That should be fun to use.
