I beleive these were used in miter boxes.
Take a good look at the teeth, both are probably cross cut and both were probably purchased along with a miter saw. Differences in height of blade is due to fit/use with a specific size miter box. Did you find any miter boxes?
T.Z.
I'd have to check, but the one on the left looks more like a carcass saw, and the one on the right looks (by the handle anyway) to be earlier than 1940s. Have you checked the Disston Institute?
-m
Glaucon
They're from large metal miter boxes, I have several of the boxes and the saws. They would be very awkward to use freehand.
John White
You may be a bit surprised how compact the boxes are! A few years back, I had a very bad "miter box problem". I bought every one I came across and the result is I have some 17 workable boxes in my basement of all types and manufacturers plus a couple or three that are parts only.
As someone else posted the saws are too large and unwieldly to be used without the box, although I've come across more than a box or two without saw. You could make a box out of hard maple (or some other similarly suitable wood) so that you could use the saw. The box would be three sided, with the height (inside) just a bit less than the distance of the underside of the saw back to the saw teeth. Width (inside) would be 4, 5 or 6" to coincide with the width of the stock you want to cut. Length is maybe 16". Simply cut across both vertical pieces some plumb cuts--one at 90 degrees to the length of the box and two at 45 degrees (opposite each other) and you're good to go. Use a shooting board to spiff up the cuts you've made and Bob's your uncle.
T.Z.
The latest (in my area) Roy Underhill program has him using large saws in a metal miter box, and that sucker ain't small. Might be worth a look.
Jim
Here is a pic of one of these saws in a mitre box. The saw has about 21" of thoothed edge.The Professional Termite
