Hello fellow woodworkers, my name is burl and this is my first encounter with this valuable resource. I am a 28 year old cabinet maker from Oceanside, Ca. Such a pleasure to be in the company of so many who share the same passions for woodworking as i do. I just bought an old delta cabinet saw from a retired contractor for a very resonable price. Two things were missing from the saw, the serial number plate, and the wheel lock for the blade hieght adjustment. I have since taken the saw apart to have top resurfaced and to toroughly clean the interior. My questions are many, Is there resources other than delta to locate parts, is the original gray paint available, what is the best trunion lube, would it be wise to have the motor serviced (opened it part way and noticed caked dust), and is there a motor cover for this 1960’s something saw. I appreciate these old machines like old automobiles, built to last, and I hope to have this saw when I retire. Any advice or pros and cons would be greatly appreciated. Happy Mothers day. Much respect, burl
Hi Burl,
Can't be of any help with the saw. Just wanted to say, tho, I think you've got one of the best names for a woodworker! :)
Scott
Burl, try this link: http://www.oldwwmachines.com/delta/Delta.asp
Scroll down the page and you'll find a couple of places that are supposed to have parts.
Steve - in Northern California
Burl
Your saw sounds a lot better than mine. My Unisaw is about an early 50's vintage, spent its life in a window shop cutting aluminum frame, was laid to rest in a open sided barn, rusted a bright rust red.
Seller was the grand son, saw was in the way, heavy and ugly. Price was $400, I figured it was a deal. The lady said I was the first to call, when I picked it, she had nearly 800 calls and left the house.
Cleaned out the dust hopper, all the insides, gears, top was level but took a lot of work to get it cleaned up. Lubed it with Teflon.
The motor was original, clean it up and used it hard for about 6 years when it died. Put in a new one with more HP. After about 5 more years, the main bearing got noisy.
I found some rattle can spary paint that was very close to the original, most people cannot tell the difference anyway.
Put on a new Unigard, 52" unifence. All the parts and fixtures came from Delta, fit perfectly.
Built a dust cover with cabnet hindges, latch, cut a hole in the back bottom for my dust succer, and have loved it ever since.
I never thought about having the top surfaced, it has some dark stains, but some I added of my own over the years. I wax it about twice a year.
Great machine.
Curt
Burl, an older unisaw is a great find. I have a 1942 unisaw. When I bought it I had many of the same questions. The saw is in perfect running condition but it isn't the prettiest to look at. I called the Delta service department told them what I had and asked if I can still get any parts for it. I was told that I could get any part I needed, and also if the 1hp motor quit working the 3hp motor will fit with a new pulley. This is because the hole for the motor is round not square. I asked if I could get the same color paint that was used back then it is also no problem. I haven't had to do any work to it to keep it running smooth, I plan on painting it in the next few months when I move to a new house. In the 65 or so years the unisaw has been around not too much has changed. The older saws are heavier but the internal parts are still pretty much the same.
good luck with your saw.
Steve
Burl. The SawCenter has any part that you are likely to need.They also have an instruction sheet that you can print out. http://www.saw center.com 1-800-850-8359I have just finished rebuilding the spindle on my old unisaw. They are good folk to work with. ¬¬¬¬¬¬¬¬¬¬¬¬PAT¬¬¬¬¬¬¬¬¬¬¬
