My buddy got this plane at a yard sale and I agreed to clean it up and get it working for him. As I took it apart, I was surprised to find no clues as to it’s origin. It’s a little rusty, but everything came apart easily, so I figure that it was stored pretty well over the years.
When I began cleaning up the plane iron, I found some faint lettering that says “L. Bailey, PATENTED, August 31, 1858”. A search for L. Bailey planes gave me quite a bit of info about dating planes, but nothing seems to fit this one.
Can anyone shed some light on this plane? It’s a low angle block plane with an adjustable throat. The thumbwheel in the back seems to be for adjusting the angle of the plane iron, and the plane iron has machined slots that serve no purpose that I can see.
Dave,
The thumbwheel adjusts the depth of cut. Check your photo 6. The flat vertically mounted piece with a "mouth" just in front of the thumbwheel engages the thumbwheel. Then the other end of this piece has fingers that engage the machined slots on the back of the plane iron. Now when you move the thumbwheel up and down the flat piece causes the iron to move back and forth in its bed.
Good luck. It should clean up into a sweet plane and give you a lot of experience.
Best wishes. George
You don't stop laughing because you grow old. You grow old because you stop laughing. - Michael Pritchard
It probably is an Excelsior block plane made by Stanley. Check out the type study in John Walters book on block planes
I have a stanley plane that appears to be an exact match for yours. I did not buy this particular plane, my block plane was gone from the toolbox with this plane left in its place. I had a stanley plane that was completely different, the iron adjustment is on the bed angle like most planes.Even after fetteling this plane so it would work to my satisfaction, it sits in a drawer rarely used.
mike
The depth adjuster looks just like my Stanley 9-1/2. But the 9-1/2 is not a low angle plane.
Edit: Block planes have a lower bedding angle than a bench plane, but with a bevel up blade the angle of attack is pretty much the same as a bench plane. Check out this page: http://www.supertool.com/StanleyBG/stan2.htm
The 60-1/2 is a low angle with a bedding angle of 12 degrees. The 9-1/2 sits around 20.
Edited 1/6/2009 1:02 am by jase
