I was recently made aware of an oil-varnish mixture consisting of equal parts turpentine, alky varnish and pure tung oil. I have seen an example of the finished product and the sheen is magnificent (not too glossy with a beautiful rubbed appearance). I would like to use this finish but am uncertain on how best to apply the coats. Normally an oil/varnish finish is applied and then wiped off so that the finish is built up with each coat. Is this the best way to apply this mixture? Can it be buffed after say the 4th or 5th coat? Should it be waxed as well? If so what type of wax should be used? How hard or durable is the finish?
Have you ever seen an example of a Waterlox finish? It is just what you are describing and comes in one can not three.
To answer your question about the mixture described;
Wipe on a copious amount, let it sit for about ten minutes and then vigorously remove the excess.
Be extremely diligent on the disposal of all oily rags. Lay or hang them out to dry to avoid spontaneous combustion. Fail to do this and even the best day can be ruined.
Repeat as desired. This type of finish will not build up an appreciable film or topcoat no matter how many coats are applied.
You can give it a buffing after a number of coats with steel 0000 wool. If you want to use wax be sure and let it cure for a month at least. Any of the furniture waxes can be used. For a softer sheen, apply the wax with 0000 steel wool and then buff it.
Durability depends on use. A chest of drawers won't get the constant use of a dining table. With a little care a finish will last quite a while.
Just an opinion (or editorial);
There are so many recipes and favorite mixtures out there. I always wonder why?? Why not just use one can instead of three. For some reason many feel the need to reinvent the coatings they are using.
Peter
Thanks Peter. Waterlox is not readily available in Canada to my knowledge. However Lee Valley Tools sells a wiping varnish. It may be similar. Regards, Pinkopalino
