Hey guys,
I recently decided that woodturning would be a fun branch of woodworking I should try. So, after reading a couple of articles, I went to the local woodcraft and wreslted home a jet mini lathe(non variable speed). Since I probably will not upgrade to a larger lathe for a few years, I would like to keep it in it’s pinnicle shape. There is a thin film of protectant over the surfaces. Should I wipe it off with 409 or clean it up with mineral spirits. Also, should I clean the cast iron with some t-9. Any advice on setting up, maintainence of a lathe would be appreciated. Thanks!
Peter
The mineral spirits will work far faster than the 409, keep it off the painted parts though. The T9 will keep your newly cleaned parts from rusting.
I may jump in on this thread too, as I just bought a new lathe and have zero experience. The electrician is coming Monday to drop 220V in the basement, so I should be turning tomorrow night.
We may not hear from you for a week! Turning is more fun than a barrel of monkeys. Get a lab coat with no pockets, or you will be finding wood in places you forgot you had!------------------------------------
I have the same lathe, 2 years now, its addictive. Just my 2 cents but I do the following on an a regular basis (weekly)
1. unless the design has changed the motor is mounter below the lathe, I keep the area clean as possible, its really the only design flaw I would comment on, with that I use compressed air or my shop vac to remove dust after each use.
2. I lightly "brush" the exposed iron bed with 0000 steel wool and apply a coat of quality past wax to assist is rust prevention and allow for easier movement of the tail stock and tool rest.
3. I use a few drops of 3in1 on the tool rest mechanical parts and also on the tailstock.
Also, let me suggest you look into pen turning its very rewarding and allows for some very creative artwork.
You referred to pen turning as very creative. I'm curious as to what types of pens you turn. Maybe you could post some pictures? Do you use pen kits or turn the entire pen short of the tip from wood?
I've been pen turning for a year and a half and quickly got tired of turning "conventional" pens, that is, buying kits and turning the barrels. Adding some curvature makes a pen a little more unique, as does lamination, but I find it very limiting in form. Now, I buy various pen kits and dump all the parts into a bowl. I custom-build each pen using, for example, a Slimline tip, a Streamline centerband, and a European Clip/Cap. But you can only be so creative. I see bowls as a wider outlet for creativity.
Neverthess, I still enjoy turning pens. They are quick, practical, and everyone ooohhs and aahhhs over them.Chris @ flairwoodworks
Probably cosmoline or something like it. Mineral spirits, naptha, wd-40 will remove it.
