I need a slot cutter for my router with about a 1″ depth of cut. The slot need to be exactly 0.920″ deep. The width of the slot has to be 0.210″ so I had my 0.250″ slot cutter ground down to a 0.210″ width but it will only reach 0.625″ deep, max. This is for an on-going production run and is not a one time thing.
Anyone ever had a 1/4″ straight bit ground down to a smaller diameter? Or, does anyone make a 7/32″ straight bit?
Any other suggestions?
PlaneWood
Mike, you might be able to get a thin kerf blade made with the proper thickness (perhaps Forrest would do this for you). You could set it up to cut 1" deep. Just a suggestion.
John
Two suggestions --
1) You're willing to go 9 thou over with the 7/32 bit. Are you willing to go 13 thou under? If so, get a 5 mm bit.
2) Cutting nearly an inch deep with a straight bit is going to take several passes -- that is, lots of labor. Can you do the job with two passes of a table saw blade? If you need to be able to plunge-cut, you can do that on a table saw. Use stops to ensure that the workpiece can't get jerked away from you. With a little looking around, you can find saw blade diameters as small as 4".
>> The width of the slot has to be 0.210" ...
Would it make sense to use a narrower blade and make two passes?
>> ... does anyone make a 7/32" straight bit?
A tool and cutter grinder will be able to reduce a straight bit to whatever diameter you like. Ask at local machine shops to see who sharpens their end mills.
Go to the McMaster-Carr or MSC web page and look at metal slitting saws. If you're willing to modify a stock tool, there are candidates in HSS, cobalt and carbide. The tooth geometry is not ideal, but if you're planning on having it ground anyway, that can be corrected.
Does it need to be for curves or is it just straight. Knowing the application would be helpful. A lot of the guys at work always ask me for certain tooling and I ask them what they are trying to do. Often we re-design it to use more standard off the shelf tooling.
http://www.thewoodworkerschoice.com lists a 7/32" x 1" flute in their catalog as 0436 Viper # 732-4-DFS Couldn't find it in their online catalog but some sites don't search that easy.
The slot is just a straight cut centered on the edge of a 13/16" thick board. Whiteside makes a 7/32" straight bit but with only a 3/4" depth of cut. The shaft is 1/4".
I guess I could set up a dado blade on a table saw. Only thing is that I gave my table saw to my son a couple of years ago! He only lives a mile away though.
The only dado blade I have is a real old sears adjustable dado that's not the best. What dado blade would be advised to get an accurate thickness?
If you are using a standard dado, the two outside blades will usually be .250, but I have used two regular sawblades of the same size and # of teeth before with good results.
What are you doing this for anyway? Or what is the application? Maybe there or other options that we can offer that you may not have thought of.
Making handles for reproduction #44 Miller's Patent planes.
The folks at Memphis Machine can make you a cutter for any application to your specification.
I think you are going to get too much chatter from bit deflection to hold your tolerance with a router bit that small, and going that deep.
That was my thought too re: a straight bit. I think I'll purchase a newer style adjustable dado and give that a try.
Mike,
Your right to go with the dado. I would make long strips of stock and then a fixture that uses the slot to hold it and then route it to shape.
I know, I know, you didn't ask me but I couldn't help it.
Mike,
I've never seen a dado blade that went below 1/4". You need less than .25, so I'm not sure this'll be a viable approach. Or, I may just be smoking something?
If the dado approach doesn't work out, something that might just fill your bill exactly would be a slot cutter for your router ... one that is set for exactly 1" deep, and is ground down to your desired width of cut.
John
If you are thinking saw blade, the tooling manufacturers make grooving blades in different kerfs, and could make one in whatever size you want. The advantage is the groove would be flat-bottomed, if that is important, and the geometry would be right....with dado blades, if you're just using the outside blades, you'll get the same ridge in the middle you get with an ATB.
Same principle with a shaper, if you have one....you could get a grooving tool. That's a big cut for a router bit, if you go that way.cabinetmaker/college woodworking instructor. Cape Breton, N.S
I believe some wobble-type dado blades will cut less than 1/4".
Another way to do it is with two passes of a standard saw blade. So it takes two passes instead of one. You can do a lot of extra passes for the cost of a custom saw blade.
Guess you didn't read my post on the 7/32" router bit with 1" flute. Now I know the application I wouldn't suggest the router bit route anyway. Two passes with a sawblade would be simple. They used to sell wobble washers so you could make a blade wobble and get that 7/32" kerf or stack some thin kerf rip blades with spacers.
adrian's response got me thinking- maybe you could do it with a .210" width slot cutter on a shaper or a modified big router bit. you would then have a 1/2" shank, maybe even with a bearing or rub collar for consistent depth. it would also be a lot easier to run the stock lying flat on a table up against a fence than run a router down a narrow edge. your rate of stock removal would be greatly improved as well. cutting a 1" deep, .210" wide groove with a little router bit will be deathly slow- especially if you have a lot to do.
m
How about stacking a standard width (1/8") rip blade with a thin kerf (3/32") rip blade and use a shim between the two to get the final slot width? With 24 tooth blades, there should be enough clearance between the teeth to "interleave" them.
