I have a quandry. The wine cabinet I’m building for the War Dept. (wife) has a pullout shelf below the top. The space is 15/16″ high, the frame that will be used to attach the top is 2″ wide. I think I can make slots and attach the top with screws on an angle. Unfortunately I am unable to reach back that far, maybe 1/2″. If you look at the attached pictures you can see what I am dealing with.
The cabinet is made from plywood, never made a piece of furniture from plywood, I wanted a challenge, hopefully it will turn out good.
Barry
I have had a similar application and I used 1-1/4" sheet metal screws that had a hex head and used my rachet wrench and appropriate socket- the screw had a slot and hex head. I purchased the screws at a Ace Hardware.
I didn't even think about that approach. Did you route a slot in the frame then attach the screws?
Barry
I had a dust panel frame at the top so I drilled holes in it but I forgot to counter sink them before gluing it in so when I installed the screws to hold the top the heads of the screws stuck down. Hope this helps
Why not just drill access holes through the lower shelf? They probably won't be visible in the finished piece, but if they bother you just plug them afterwards.
David Ring
If you're using a plywood top, why not attach it with biscuits? I've had good luck with that method. There's quite a bit of room for error. Just make sure you're happy with the placement cause it ain't comin off again.
I should have mentioned the sides and shelves are the only plywood parts. The tops, edging, doors, glassware rails, feet, and bottle racks will be made from solid material.
I used the sheet metal screws option, and so far it has worked great. I routed 4 slots 1/2" wide 3/8" deep and punched through with an 3/16" bit centered in those slots.
I have a finishing problem/concern now. I'll address in another post.
